Hello,
i don't know if it is only my problem or it is a known one.
I cannot connect to my emby server nor with pin nor with manual login.
Can anyone give me some hints?
Cannot Sign-in
Re: Cannot Sign-in
what version MrMC are you on? Emby server version? debuglog might have some info
Re: Cannot Sign-in
Emby server Versione 4.3.0.8 beta
Debugging log is K84Bb.log
after trying to log with pin to emby server
About Mrmc version i think it is the last official on ATV4, where to check it?
Re: Cannot Sign-in
and is it working on a stable v4.2.1.0?
Re: Cannot Sign-in
I have just installed 4.3.0.8 beta (against my better judgement) and its all working fine here
- Montoya
Re: Cannot Sign-in
Latest Emby server changes doesn’t affect any MrMC login issues.
Only Emby issue remains is already reported in TF threads multiple times...
Re: Cannot Sign-in
Sorry, i don't understand.
So, it is only my problem.
What does log say about login failure?
Re: Cannot Sign-in
It failed to connect, could be few things but there is no specific “explanation “
Seems you are the one with the issue, I don’t see it and all seems ok on that beta version.
Edit: it could be that beta introduced some login changes that you are triggering and I am not... it has happened before. Any specific reason you are not using stable version? And was stable logging in ok?
Re: Cannot Sign-in
Actually it has been a few months that i didn't use emby with mrmc.
I tried this days so i don't know when the problem started.
I'll give a try with stable version
Re: Cannot Sign-in
I solved my problem, now i can login.
The problem was a setting in emby server
