As Subject says, my mrmc simply crashes asap i click the xbmc remote button on the website in my browser. cant get a log file cause mrmc creates alway<s a new log on start....
Works well on my raspi with kodi 16 running
Any Suggestions ? )
kind regs
Mrmc crashes after a xbmc remote play was called via a website and the last entry in the old.log says :
17:56:08 T:6159953920 DEBUG: JSONRPC: Incoming request: {"jsonrpc":"2.0","method":"Playlist.Add","id":"Playlist.Add","params":{"playlistid":1,"item":{"file":"http://XXXXXXXXXXX/files/4/4045.mkv?st= ... 1458242308"}}}
No other errors are listed and in logging all options are marked.
Any hint ?
regards
Ertina
Which version of MrMC ?
Can you describe exactly what you are doing ? "xbmc remote play was called via a website" is a little vague. We want to exactly reproduce what you are doing so we can trigger the error.
