HomeMenu JSON commands not working?
houser
Post by houser » 26 Apr 2019, 16:29
Hello,
Happy user here. MRMC is now at a point where it is very useful, with Atmos and all. Fab!
Not sure if this is platform specific, but I am on Apple 4k with latest version 3.8.1.
I have my own Kodi remote built (iRule) which also works great.
Apart from just the home menu command.
Is this command different on this platform for some reason?
Grateful for a hint? Many thanks.
This works on both Kodi 17 and 18 on mac and Win:
go to home menu:
jsonrpc?request={"jsonrpc":"2.0","method":"Input.Home","id":1}
Re: Need two JSON commands that are not working?
Post by davilla » 26 Apr 2019, 17:14
should be that same, debuglog when you send either.
houser
Post by houser » 26 Apr 2019, 20:11
Alright, thanks. Will have a longer look and return with log!
houser
Re: HomeMenu JSON commands not working?
Post by houser » 27 Apr 2019, 11:49
Hello,
Edited my OP as only the home menu is the issue (user error on the other).
Using the above command does not add anything to the debug log so nothing to send so far AFAIK...
Just checked that it works fine exactly as is on Kodi 17 and 18 Win and Mac.
If it helps, Debug log on Kodi 18.2 on a Mac gives this response when sending the home menu command:
2019-04-27 13:46:07.461 T:4581041600 DEBUG: Activating window ID: 10000
2019-04-27 13:46:07.512 T:4581041600 DEBUG: ------ Window Init (Home.xml)
houser
Post by houser » 19 May 2019, 20:59
FrankPax wrote:
18 May 2019, 08:31
Does your file finish with json?if not, try placing that at the end
Many thanks Frank. But all my commands work except Home menu for some reason
so that is not the issue.
And that same Home menu command works as expected on vanilla versions of Kodi on Mac, PC and Linux.
Ah well. No biggie. Will probably start working at some point..
Thanks again.
Post by amet » 20 May 2019, 05:22
I think Frank is a spammer :)
I will have a look at “home” and why it doesn’t work...
