switching to 120hz output instead of 24hz
Post by cosmoxl » 13 Mar 2019, 17:47
MrMC is switching for the file below to 120hz output instead of 24hz output. See the log and the mediainfo below.
FYI, playback in the Plex app on shield is correct at 24hz output.
https://paste2.org/205zFdJ3
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 41 min 33 s
Bit rate : 10.7 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.215
Stream size : 3.11 GiB (94%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Re: switching to 120hz output instead of 24hz
Post by koying » 13 Mar 2019, 18:14
As 120 is a multiple of 24, this is expected, really (same with 25 and 50). MrMC goes to the highest multiple.
Is there an issue with those playing @ 120?
Post by cosmoxl » 13 Mar 2019, 21:18
koying wrote:
13 Mar 2019, 18:14
I understand the concept. I should have explained why I didn't like what was happening. Oddly enough, it looks choppy on my TV. Playback in the Plex app, which switches to 24hz, looks proper.
Would it be a problem to just switch to the actual matching framerate and not a higher multiple? Speaking of that, I get a smoother picture watching 25hz material at 25hz rather than the 50hz output that MrMC does.
Post by koying » 14 Mar 2019, 10:32
It makes actual sense with 25/50 for interlaced, as there the framerate might be doubled (and it's actually the case on shield). Not for 24/120, ofc.
I'll see if we already have the interlaced information at framerate switching time, and not use multiple if not interlaced.
In any case, it doesn't make sense to multiply by more than 2, factually.
Post by cosmoxl » 14 Mar 2019, 12:59
koying wrote:
14 Mar 2019, 10:32
Sounds great!
