Playback crash.
Playback crash.
Post by cosmoxl » 08 Mar 2019, 15:57
I'm seeing a crash with one file, though maybe there are others that would have the same problem. I can't test them all. :)
But, this is the first I've seen this. I click to play a video and not much happens but eventually I'm taken back to the Shield home screen and see the interface as if I have a video playing in the background. e.g. the name of the movie and then a button to open or to stop it.
I've tested with and without acceleration and the same thing happens.
If I click the "open" button on the shield home screen I'm taken back into MrMC as if It's starting from being fully closed down.
https://paste2.org/FbPNejkc There' s a log. Looks like it failed to create audio renderer.
And the mediainfo for the file is
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 h 7 min
Bit rate : 12.3 Mb/s
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.326
Stream size : 10.9 GiB (69%)
Default : Yes
Forced : No
Audio #1
Format : DTS ES XXCH XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 4 564 kb/s
Channel(s) : 7 channels
Channel layout : C L R Ls Rs LFE Cb
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 4.06 GiB (26%)
Title : Surround 6.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 1 007 kb/s
Channel(s) : 6 channels
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : 9 ms
Stream size : 918 MiB (6%)
Language : English
Default : No
Forced : No
