When skipping, the intervals are not shown
Cantello
Post by Cantello » 08 Mar 2019, 11:16
When skipping videos, the skip intervals are not displayed in Ariana, whereas in Opacity they are shown normally.
Explanation: if you skip several times with direction pad right/left, any skip within the interval specified in the playback options is added together and shown on the progress bar as per the skip increment options and then executed together.
Using MrMC 3.8 on Apple TV 4k.
Re: When skipping, the intervals are not shown
Post by amet » 08 Mar 2019, 12:44
Will look at it ...
I seem to remember that on Apple TV it’s showing when using Siri expert remote mode, is that what you are using?
Cantello
Post by Cantello » 08 Mar 2019, 19:57
08 Mar 2019, 12:44
Will look at it ...
Yep, that's what I am using. It was my understanding that without that feature, it would be much less practical to use a universal remote (Harmony in my case).
Post by amet » 09 Mar 2019, 03:47
Ah, of course... thought you are using Siri
