[Request]Would Jellyfin be supported
lvvllc
Post by lvvllc » 28 Feb 2019, 18:16
I just wonder would Jellyfin be support later?
MediaDevil
Re: [Request]Would Jellyfin be supported
Post by MediaDevil » 26 Mar 2019, 12:04
I'd like to see this too. What is Jellyfin: "Jellyfin is the Free Software Media System that puts you in control of managing and streaming your media. There are no strings attached, no premium licenses or features, and no hidden agendas".
I've tried connecting to my Jellyfin server on ATV 4 using the MrMC Emby service. And it doesn't really work very well. It does connect. Libraries are found and displayed. But the UX isn't smooth (crashing/hanging, libraries don't always load). Playback does work if you manage to navigate the library.
Some discussion on Reddit: https://www.reddit.com/r/jellyfin/comme ... r/ejas9lz/
Post by davilla » 26 Mar 2019, 13:38
If someone could add a test account on their jellyfin server for MrMC devs to test. You can email details to support@mrmc.tv
MediaDevil
Post by MediaDevil » 26 Mar 2019, 14:47
Hi davilla, I'm not quite sure how (there isn't an Emby Connect equivalent) but will ask on the Reddit sub. Hopefully someone can.
Thanks.
anthonylavado
Post by anthonylavado » 26 Mar 2019, 17:24
Hi @Davilla,
I’m part of the Jellyfin core team. We’re just getting ready to put out a new version, and as soon as we’re clear there, I’ll send over some details.
Post by amet » 26 Mar 2019, 17:36
@anthonylavado
If you could let us know what the API differences are that would be great, we could work on getting it in MrMC.
Feel free to get in touch on support at mrmc.tv if it’s easier
Post by amet » 26 Mar 2019, 18:21
I have connected to it using emby manual sign in and I see no issues or crashes... small library, but nonetheless ... all good.
could you post a debuglog when it crashes for you or a way for us to reproduce.
MediaDevil
Post by MediaDevil » 26 Mar 2019, 23:51
26 Mar 2019, 18:21
Hi Amet, I just tried again.
No crashes. But very slow. Jellyfin 10.2.2. ATV 4. MrMC 3.8. Arianna skin. What I saw:
  • Homescreen seems fine. I was mid way through an episode and it appeared ready to resume. As well as recently added episodes.
  • Accessing Movies - nothing loads. Screenshot below.
  • Accessing TV - part loads the library, around 25 out of 70 shows total. Can drill down into seasons and episodes fine. Playback is fine.
Log: https://pastebin.com/a8KMNfPM
Movies section:
Post by amet » 27 Mar 2019, 03:25
I wonder if it’s not the 3.8.1 that I am testing vs 3.8.0 that you have.
Wanna try 3.8.1 TestFlight ? Send us a mail to support and I’ll add you in, need your Apple ID you used to get MrMC
MediaDevil
Post by MediaDevil » 27 Mar 2019, 10:22
Cheers. Dropped you a mail.
