Couldnt open database
brallor
Post by brallor » 24 Feb 2019, 18:21
Hi
Running a Windowsserver with Kodi v17 on with mysql server, tried to connect using MrMC.
https://pastebin.com/TwFqm9np
It seems that my username "kodi" is changed to something with Asus router, very strange.
Re: Couldnt open database
Post by amet » 24 Feb 2019, 18:51
Can you connect to MySQL database from your computer?
19:14:39.608 T:6178910208 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?n ... nloadCache
That is also a strange error, should not be 404 unless network/internet is down
brallor
Post by brallor » 24 Feb 2019, 18:56
Yes, and booth my ATV 4K and server with mysql is connected to the same router.
Network and internet is working :/
Post by amet » 24 Feb 2019, 19:17
Error is clear, MySQL won’t allow user “kodi” to connect... not sure what to suggest except rechecking the network and possibly restarting the router
[1045](Access denied for user ....
