How to Watch Items Not In Library
wdpcpa
Post by wdpcpa » 11 Feb 2019, 05:01
I was stuck on XBMC Eden forever. Why change if it was working. And I used the default skin. I think it was called "Confluence". Then went to Frodo.
In those skins, I almost always clicked Videos which gave me the pretty graffics but also gave me folder selection. Each folder showed up. Inside the folder the NFO files were read and the display was still pretty.
I had a folder I called "One off Stuff" and that is where I put things to watch and delete. It was not part of the "Library". It didn't have NFO files or anything else. What is the equivalent to that in MrMC where I can just drop a file and delete it without adding to the library.
I see I can go through Sources but my "One Off Stuff" folder is pretty deep going down through sources.
Re: How to Watch Items Not In Library
Post by amet » 11 Feb 2019, 07:44
Add “One off Stuff” as a source, set content to none and mark it to show on home screen... you need to use opacity or Ariana skin for it to work and folder will be shown on home
wdpcpa
Post by wdpcpa » 11 Feb 2019, 15:06
Thnx for the quick response.
wdpcpa
Post by wdpcpa » 11 Feb 2019, 15:35
I use the skin that came with MrMC. I looked and it says Opacity.
But I don't see how to add the folder to the home screen. Is it "Add To Favorites"?
Post by amet » 11 Feb 2019, 17:00
wdpcpa wrote:
11 Feb 2019, 15:35
No, it’s called “show folder on home”
wdpcpa
Post by wdpcpa » 12 Feb 2019, 03:55
OK - got it. Forgot how to add the folder.
Thanks.
badseed
Post by badseed » 16 Feb 2019, 14:45
Im using Ariana skin were is this option ?
Post by amet » 16 Feb 2019, 14:50
badseed wrote:
16 Feb 2019, 14:45
It’s the same on all the skins, context menu(long hold select) over a source
badseed
Post by badseed » 17 Feb 2019, 06:54
thanks as always
badseed
Post by badseed » 17 Feb 2019, 11:04
16 Feb 2019, 14:50
badseed wrote:
16 Feb 2019, 14:45
Im using a External Drive (My Book) attached to the Nvidia Shield to pull source folders from, Still cant figure this out?
Cant see a "context menu(long hold select) over a source" option to “show folder on home” only see had to Favourites?
