pvr simple client
kamil66
pvr simple client
Post by kamil66 » 08 Feb 2019, 16:23
Hello there is a big problem with a simple customer PVR the sound is offbeat it's amazing it's been a month we're waiting for the fix finally even with this new update is still the same shit I bought this application that works well in the beginning after some crafts on your part it became a disaster suddenly I turn to kodi I feel that we are much more with amateurs than prosthe updates is to fix the bugs but with you it's quite the opposite you make us a little dressing with two balls and you tell me that it is a good version do not tinker for apple tv because it works well for the nevidia shiled you are unable to solve this problem unlike kodi if you know not do things copy at least on Kodi a very angry customer who recommended you but who will recommend you more thanking you
Montoya
Re: pvr simple client
Post by Montoya » 08 Feb 2019, 16:26
kamil66 wrote:
08 Feb 2019, 16:23
Congrats, all in one sentence...
Where are all the dots, comma's, capitals and paragraphs to differentiate :D
Don't have a clue what you are saying :shock:
Apple TV 4K 64GB tvOS 12.1.2, Win10 Pro x64 1809 build17763.379
TVMosaic server build 17051, Emby server build 4.1.0.16 beta
kamil66
Post by kamil66 » 08 Feb 2019, 16:48
Hello you will do better to work and improve the application and adjust them. That does not work that of commenting points and commas if you had a forum in French one could have written correctly well cordially
kamil66
Post by kamil66 » 08 Feb 2019, 16:51
prenez le temps de régler le problème de PVR simply client car l'image et au ralenti et un décalage avec l'audio it seems to me that you took a specialist in your team for that what does he do
Post by koying » 08 Feb 2019, 18:19
Et on est sensé sucer de notre pouce le problème?
Quelle source? Quel format? debuglog , svp
kamil66
Post by kamil66 » 08 Feb 2019, 19:02
Good evening the problem comes from the application itself the same simple PVR client works perfectly with Apple TV on my two boxes Nvidia shield the audio and the image and quirky test with m3u that works perfectly the hard problem since the last two update of MRMC it's weird because with Kodi it works perfectly thank you
Post by koying » 08 Feb 2019, 20:19
Bon, tu es francophone ou pas?
Telling me it works in other space-time doesn't really help to pinpoint the issue ;)
Montoya
Post by Montoya » 08 Feb 2019, 20:54
kamil66 wrote:
08 Feb 2019, 16:23
Hello, there is a big problem with a simple customer PVR, the sound is offbeat :!:
It's amazing, it's been a month we're waiting for the fix. Finally even with this new update, is still the same shit :evil:
I bought this application that works well in the beginning. After some crafts on your part, it became a disaster suddenly :(
I turn to Kodi. I feel that we are much more with amateurs, than prosthe :oops:
Updates is to fix the bugs, but with you it's quite the opposite :shock:
You make us a little dressing with two balls and you tell me that it is a good version :?:
Do not tinker for apple tv, because it works well :!:
For the nevidia shiled, you are unable to solve this problem unlike kodi.
If you know not do things, copy at least on Kodi.
A very angry customer, who recommended you, but who will recommend you more :idea:
Thanking you :D
I used the original text and added some dots, commas and capitals, to clear some things up.
@kamil66,
Could you please use this translator, because it does a better job than most others:
https://www.deepl.com/translator
kamil66
Post by kamil66 » 11 Feb 2019, 13:45
Hello, it's good, the problem is fixed.
kamil66
Post by kamil66 » 11 Feb 2019, 13:52
Hello remains to solve just a problem for PVR single client with the skin Ariane the keys forward back and pose does not work if we have to watch a movie on pvr single client we can neither advance nor retreat put me on pause a VOD on line m3u if you can make that touch is functional it would be great from you sorry for my English because I use a translator
