Intro-skipping
ulfthomas
Intro-skipping
Post by ulfthomas » 04 Feb 2019, 10:12
Hi.
Been a long-time Kodi-user but was made aware of MrMC early this year and instantly switch to it on my Apple 4K. :D So far I love it! Excellent experience because everything works. (WAF increased as a result of me having less room for modifications. :lol: )
I do have one question: We watch a lot of series and when starting these (specifically sit-coms) MrMC tends to jump passed the intro - which is a problem because most of the times there are something happening in the show prior to the actual intro. I also experience MrMC skipping forward 10 minutes if it cannot find a clear intro end-point.
I've tried searching but I cannot find any info on it. Is there anything I can do to mitigate this behavior?
Regards,
Thomas
Re: Intro-skipping
Post by amet » 04 Feb 2019, 11:30
Sounds like you have EDL files next to your video files... we do not create intro-skip and that is influenced by adding an additional EDL file using an external application.
ulfthomas
Re: Intro-skipping
Post by ulfthomas » 04 Feb 2019, 13:19
04 Feb 2019, 11:30
That is interesting. I have actually never implemented or used this feature. I have just grepped my entire disk volume for these files and I have none. (or any other file type for this feature for that matter).
Trying to find if these can be stored in a database as I run a shared Mysql setup.
Edit: Browsed through my database and cannot find any fields containing this information. Could they be stored in the .mkv?
Re: Intro-skipping
Post by amet » 04 Feb 2019, 13:23
Nope, they are not part of the database.
Where do the video files come from? If you are recording it from live tv then it’s possible that your recording software is doing it.
MrMC will just play it as you have it on your disc, debuglog will have more info about edl/comskip use or just test using your computer and play the same file... see what you get there
ulfthomas
Re: Intro-skipping
Post by ulfthomas » 04 Feb 2019, 13:31
04 Feb 2019, 13:23
I'm playing using .mkv files (not coded by myself) - and I have a feeling they are part of the container.
Re: Intro-skipping
Post by amet » 04 Feb 2019, 13:34
E-mail support @ mrmc . tv if you can share a sample for testing... as far as memory serves me, we only read external edl
ulfthomas
Re: Intro-skipping
Post by ulfthomas » 04 Feb 2019, 13:40
Will do.
