Help me permanently shut off HW VC1 decoding
MiamiVice84
Post by MiamiVice84 » 23 Jan 2019, 03:38
Hello. I still have a large number of HD-DVD based VC1 files. The Shield can play them fine when hardware acceleration is shut off, but I need Mediacodec for UHD bluray.
I'd like to have Mediacodec (Surface) shut off and Mediacodec turned on.
I tried writing this as an advacedsettings.xml file based on some other stuff I found online but so far no luck. Could someone help me tweak it?
<advancedsettings>
  <video>
    <mediacodec>
      <!--  -1 is default, 0 is never used this codec, 1 is always use this codec, bypassing blacklist -->
      <useavccodec>-1</useavccodec>
      <usevc1codec>0</usevc1codec>
      <usevpxcodec>-1</usevpxcodec>
      <usemp4codec>-1</usemp4codec>
      <usempeg2codec>-1</usempeg2codec>
      <useswrenderer>false</useswrenderer>
    </mediacodec>
  </video>
</advancedsettings>
