Live TV issues
convertapple
Live TV issues
Post by convertapple » 22 Jan 2019, 00:03
1) Settings->TV->Menu/OSD->TV menu goes to TV guide = on, but it still goes to TV channels using Amber Skin.
It works correctly using Opacity skin but that lists all Plex libraries on main menu and in reverse alpha order!, rather than grouped under Movies/TV Shows/ Music as in Amber which I'm not sure I like, though maybe I should try it out more!
2) Live TV does not remember the channel group when you exit/return from MrMc, annoying for kids.
3) It would be nice if on Settings->TV->Guide->Update Interval, it also had 'Update Time', so when MrMc starts up it can check the last time it read EPG data in (see date on epg11.db) and determine based on Update time & interval if it actually needs to re-read it in or use the cache. EPG only updates once a day so there's no need.
Tested on FireTV/ATV4 running latest MrMc release version
SΛSϾHΛ
Re: Live TV issues
Post by SΛSϾHΛ » 05 Feb 2019, 11:24
A few more information would not be bad. What is TV realized with?
.m3u, TVHeadend, DVBViever, DVBLink etc.
SET-TOP-BOX: Apple TV 4
FW: tvOS 12.1.2
Front-End: MrMC 3.8.0
SET-TOP-BOX: Apple TV 4K
FW: tvOS 12.2 (Beta 6)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Montoya
Re: Live TV issues
Post by Montoya » 05 Feb 2019, 13:11
convertapple wrote:
22 Jan 2019, 00:03
As far as I know from previous MrMC Dev posts, the only skins that currently get active support, are Opacity and Ariana. All others skins are phased out and considered End of Life and will possibly be removed in one of the future MrMC builds.
Apple TV 4K 64GB tvOS 12.1.2, Win10 Pro x64 1809 build17763.379
TVMosaic server build 17051, Emby server build 4.1.0.16 beta
