TV Infobar Topic is solved
Any Opacity skin issues go here
Re: TV Infobar
Post by amet » 25 Mar 2019, 16:06
We don’t have double click, long hold Select ... maybe
Ted377
Re: TV Infobar
Post by Ted377 » 25 Mar 2019, 16:10
Do not get me wrong. I do not mean a direct double-click. Scenario ... I click on OK once to call up the infobar. When the info bar is displayed, I click OK again to display the description. I only confirm the current program to get the description displayed.
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 4)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190721.1323)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Ted377
Re: TV Infobar
Post by Ted377 » 25 Mar 2019, 16:24
Click OK to show Infobar…
Once the Infobar is displayed, click OK again and the description will be displayed…
NAS: QNAP TS-231P
Re: TV Infobar
Post by amet » 25 Mar 2019, 16:53
it might not be as simple as that, due to how the click calls are handled :(
Ted377
Re: TV Infobar
Post by Ted377 » 25 Mar 2019, 16:57
25 Mar 2019, 16:53
Can it somehow refer to the current (NOW) broadcast? So the line currently displayed in color. Just an idea ☺️
NAS: QNAP TS-231P
Re: TV Infobar
Post by amet » 25 Mar 2019, 17:06
not sure I follow? try again :)
Montoya
Re: TV Infobar
Post by Montoya » 25 Mar 2019, 17:23
25 Mar 2019, 15:49
What I would like to establish is what should be shown and when... current state is like @Ted377 wanted and @Montoya is not happy :)
LOL :D
25 Mar 2019, 15:49
Let’s hear what works and why and coding it in should not be an issue...
With feedback already done I only focused on control functionality, keeping things simple how to control MrMC ;)
How things look now with the info bar, like fonts, position of info icons, at this point, is not important to me and can easily be taken care off later, because basic control functionality is what matters now to me and is broken, compared to 3.8.0.
Some examples:
- When watching Live TV, skip FW/BW is important for me and my family, we use that quite often.
Right now, there is a bug that is activating FFW 8x/Rewind 8x, while we press Left/Right (Logitech remote)multiple times to Skip FW/BW.
- When skipping FW/BW, there is no info shown about the skip step times.
In 3.8.0 only pressing Left or Right (Logitech remote) a couple of times. we could see on screen if we did 10s/30s/1m/2m etc, so that info is gone now.
So if you guys don't know yet where to show those skip FW/BW times (maybe on info bar), a suggestion could also be to show it in middle of the screen, just like in Ariana.
For control of the Top Info Bar, I was also thinking the same control functionality as Ted377 just described in previous post:
Ted377 wrote:
25 Mar 2019, 16:24
But after reading this, that could be complicated to program:
25 Mar 2019, 16:53
OK, can we than try a TF version with long press, to get Top Info Bar and see how that goes ?
Apple TV 4K 64GB tvOS 12.4 - Win10 Pro x64 1903 build 18362.264
Ted377
Re: TV Infobar
Post by Ted377 » 25 Mar 2019, 17:24
25 Mar 2019, 17:06
Handle it like an Play/Pause Button 😉
I do not know exactly how to pay attention to this 😄
Let's say that NOW is selectable.
NAS: QNAP TS-231P
Ted377
Re: TV Infobar
Post by Ted377 » 25 Mar 2019, 17:30
Click on OK confirms this point and goes over to the description.
NAS: QNAP TS-231P
Montoya
Re: TV Infobar
Post by Montoya » 25 Mar 2019, 17:32
Ted377 wrote:
25 Mar 2019, 17:24
25 Mar 2019, 17:06
I don't follow it either, but do you realize that when Bottom Info bar is up, the controls for channel change (Up/Down) and skip FW/BW (Left/Right) are also active at that time ?
Edit: Missed your last post with picture, so now it's clear what you mean
