Okay, I see we just talk completely past each other.
I will make you a video tomorrow and show you what is meant.
@amet, video is out and I apologize for my bad englishMontoya wrote: ↑01 May 2020, 18:51 @Amet, I think Ted377 means this, which is also my preference
(Below a rewrite from what was previously written in topic and adapted for current TF)
During Live TV with no OSD on screen:
Scenario A (=Bottom Info Bar ONLY and automatic exit):
A1. Center click >> Open Bottom Info Bar
A2. No input from remote >> OSD timer closes Bottom Info Bar and screen goes back to Live TV with no OSD on screen
Scenario B (=Bottom Info Bar >> PVR controls >> no remote input >> automatic exit):
B1. Center/select click >> Open Bottom Info Bar
B2. Menu click before OSD timer times out >> Close Bottom Info Bar AND open PVR controls button bar
B3. No input from remote >> OSD timer closes PVR controls button bar and screen goes back to Live TV with no OSD on screen
Scenario C (=Bottom Info Bar >> PVR controls >> PVR controls navigation >> automatic exit):
C1. Center/select click >> Open Bottom Info Bar
C2. Menu click before OSD timer times out >> Close Bottom Info Bar AND open PVR controls button bar
C3. input from remote >> PVR controls navigation with Left/Right etc
C4. No input from remote anymore >> OSD timer closes PVR controls button bar and screen goes back to Live TV with no OSD on screen
Scenario D (=Bottom Info Bar >> PVR controls >> PVR controls navigation >> manual exit):
D1. Center/select click >> Open Bottom Info Bar
D2. Menu click before OSD timer times out >> Close Bottom Info Bar AND open PVR controls button bar
D3. Input from remote >> PVR controls navigation with Left/Right
D4. Menu click >> Manual exit that closes PVR controls button bar and screen goes back to Live TV with no OSD on screen
Scenario E (=Bottom Info Bar >> PVR controls >> Top Info Bar and manual exit):
E1. Center/select click >> Open Bottom Info Bar
E2. Menu click before OSD timer times out >> Close Bottom Info Bar AND open PVR controls button bar
E3. Up on remote >> Open Top Info Bar
E4. Navigation in Top Info Bar
E5. First menu click >> Go back to PVR Control Bar
E6. Second menu click >> Manual exit that closes PVR controls button bar and screen goes back to Live TV with no OSD on screen
Remote Controls that are active, during a Scenario step:
Active remote buttons when bottom Info Bar is on screen (during scenario step A1+B1+C1+D1+E1):
UP: Channel up
Down: Channel down
Left: Skip BW (and make multiple skips steps available when needed)
Right: Skip FW (and make multiple skips steps available when needed)
Menu : Close OSD and go back to Live TV
Active remote buttons when PVR controls button bar is in focus and active (during scenario step B2+C2+C2+D2+E2) :
UP: Open Top Info Bar
Down: Open Top Info Bar
Left: PVR Control buttons navigation
Right: PVR Control buttons navigation
Menu: Close OSD and go back to Live TV
Active remote buttons when Top Info Bar is in focus and active (during scenario step E4 ) :
UP: Open & Close Top Info Bar
Down: Navigate in Top Info Bar
Left: Top Info Bar navigation
Right: Top Info Bar navigation
Menu once: Go back to PVR control bar
Menu twice: Close OSD and go back to Live TV
@Ted377, please provide feedback on above
Yes, going to PVR controles button bar, should be a manual action and when only Bottom Info Bar is requested, it should auto close with an OSD timer and go back to Live TV.
Yes! Please
Almost there, because can you skip BW/FW, executed after Bottom Info Bar is up ?
