Testing MrMC 3.8.0 - [Invites Closed]
Montoya
Re: Testing MrMC 3.8.0 - [Invites Closed]
Post by Montoya » 10 Feb 2019, 14:31
10 Feb 2019, 13:52
Do either of you have "Boost voice channel" enabled ?
Nope, 0dB here too, in every MrMC profile I have.
jabohn
Post by jabohn » 10 Feb 2019, 17:08
Minor issue with the startup logo animation... when the app first launches, the logo screen comes up and says underneath "loading database", then for a second the app UI pops up, then it goes back to the grey screen with the logo animation, then back to the app UI.
Post by davilla » 10 Feb 2019, 19:42
3.8.0 (190210.1834)
core: try harder when m_sink->AddPackets return zero
core: iOS/tvOS, temp disable CDVDAudioCodecAudioConverter for AC3
plex/emby: home server selection fix
Revert "load home buttons once only, no point doing it over and over again"
CHG: [amc] warn if we are over-buffering demux packets
FIX: [amc] no bitstream + demux queuing -> havoc
FIXUP: pass channel config to settings audio visibility check
FIXUP: DTSHD / DTSHD_MA split
FIXUP: [droid] Remove "AMC + SD" setting; we now have a detailed one
fixme: core: add video splash detection, disable res switching if running
Montoya
Post by Montoya » 10 Feb 2019, 21:15
First tests with latest TF, checking sound level and MrMC is still 9dB lower in peak sound level, compared to Infuse, in intro clip for media below:
General
UniqueID/String                  : 315473252880609687383893136040470467834 (0xED55F03D7256EC7581E62EB18B5354FA)
CompleteName                     : K:\Movies\Bohemian Rhapsody (2018)\Bohemian Rhapsody (2018).mkv
Format                           : Matroska
Format_Version                   : Version 4 / Version 2
FileSize/String                  : 7.19 GiB
Duration/String                  : 2 h 14 min
OverallBitRate/String            : 7 650 kb/s
Encoded_Date                     : UTC 2019-01-22 15:11:43
Encoded_Application/String       : mkvmerge v29.0.0 ('Like It Or Not') 64-bit
Encoded_Library/String           : libebml v1.3.6 + libmatroska v1.4.9
Video
ID/String                        : 1
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format_Profile                   : High@L4
Format_Settings                  : CABAC / 4 Ref Frames
Format_Settings_CABAC/String     : Yes
Format_Settings_RefFrames/String : 4 frames
CodecID                          : V_MPEG4/ISO/AVC
BitRate_Mode/String              : Constant
BitRate/String                   : 7 008 kb/s
BitRate_Nominal/String           : 10 000 kb/s
Width/String                     : 1 920 pixels
Height/String                    : 800 pixels
DisplayAspectRatio/String        : 2.40:1
FrameRate_Mode/String            : Constant
FrameRate/String                 : 23.976 (24000/1001) FPS
ColorSpace                       : YUV
ChromaSubsampling/String         : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
Bits-(Pixel*Frame)               : 0.190
StreamSize/String                : 6.59 GiB (92%)
Default/String                   : Yes
Forced/String                    : No
colour_range                     : Limited
colour_primaries                 : BT.709
transfer_characteristics         : BT.709
matrix_coefficients              : BT.709
Audio
ID/String                        : 2
Format                           : E-AC-3
Format/Info                      : Enhanced Audio Coding 3
CodecID                          : A_EAC3
BitRate/String                   : 640 kb/s
Channel(s)/String                : 6 channels
ChannelPositions                 : Front: L C R, Side: L R, LFE
SamplingRate/String              : 48.0 kHz
FrameRate/String                 : 187.500 FPS (256 SPF)
Compression_Mode/String          : Lossy
StreamSize/String                : 616 MiB (8%)
Language/String                  : English
ServiceKind/String               : Complete Main
Forced/String                    : No
Text #1
ID/String                        : 3
Format                           : UTF-8
CodecID                          : S_TEXT/UTF8
CodecID/Info                     : UTF-8 Plain Text
Duration/String                  : 2 h 13 min
BitRate/String                   : 62 b/s
ElementCount                     : 2269
StreamSize/String                : 61.6 KiB (0%)
Title                            : SDH
Default/String                   : No
Forced/String                    : No
Text #2
ID/String                        : 4
Format                           : UTF-8
Duration/String                  : 2 h 8 min
BitRate/String                   : 54 b/s
ElementCount                     : 1785
StreamSize/String                : 51.8 KiB (0%)
Title                            : Nederlands
Language/String                  : Dutch
Forced/String                    : Yes
Menu
00:00:00.000                     : en:Studio Logos
00:00:44.000                     : en:Opening Credits | Live Aid Preparations
00:03:49.000                     : en:Good thoughts, good words, good deeds
00:05:14.000                     : en:Freddie finds an opportunity
00:09:38.000                     : en:Freddie takes a shopping risk
00:11:17.000                     : en:The band's first gig
00:13:27.000                     : en:Queen makes their first album
00:16:06.000                     : en:Time for a name change
00:21:03.000                     : en:The band meets with John Reid
00:22:50.000                     : en:Queen makes their BBC debut
00:24:15.000                     : en:A day full of exciting news
00:27:24.000                     : en:Queen tours America
00:29:52.000                     : en:A musical experience vs. just another record
00:33:29.000                     : en:Getting away from all distractions
00:34:17.000                     : en:Paul only sees what he wants to see
00:37:22.000                     : en:Brainstorming leads to a breakthrough
00:43:00.000                     : en:Bohemian Rhapsody isn't for everyone
00:47:33.000                     : en:Queen gives Bohemian Rhapsody to the people
00:50:18.000                     : en:Mary and Freddie start to grow apart
00:56:57.000                     : en:Freddie realizes he's lonely
01:00:24.000                     : en:Freddie throws a party for misfits
01:03:07.000                     : en:Distractions for the in-between moments
01:05:46.000                     : en:A way to involve the audience
01:10:01.000                     : en:Freddie feels betrayed
01:15:09.000                     : en:Queen capitalizes on club culture
01:19:04.000                     : en:Freddie feels the pressure of public life
01:21:42.000                     : en:Freddie wants to break free
01:26:59.000                     : en:Paul takes over Freddie's life
01:28:42.000                     : en:Freddie seems to have lost his voice
01:36:05.000                     : en:Freddie tries to reconnect with his family
01:43:26.000                     : en:It's time to face the truth
01:46:06.000                     : en:Freddie doesn't want sympathy
01:49:11.000                     : en:Freddie has tea before the show
01:52:47.000                     : en:Everyone gets ready for the show
01:55:03.000                     : en:Live Aid concert 1985
02:08:34.000                     : en:Acknowledgement
02:09:15.000                     : en:End Credits
Is this an EAC3 issue in MrMC, because in Infuse it's more detailed, spatial and vibrant and 9dB up in peak sound level during intro clip.
But for DTS media below, MrMC is more detailed, spatial and vibrant and 3dB up in peak sound level than Infuse, during intro clip, so nothing wrong there:
General
Unique ID                                : 0 (0x0)
Complete name                            : K:\Movies\The Nutcracker and the Four Realms (2018)\The Nutcracker and the Four Realms (2018).mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 16.9 GiB
Duration                                 : 1 h 39 min
Overall bit rate                         : 24.3 Mb/s
Encoded date                             : UTC 2010-02-22 21:41:29
Writing application                      : no_variable_data
Writing library                          : no_variable_data
Video
Format                                   : AVC
Format profile                           : High@L4.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Width                                    : 1 920 pixels
Height                                   : 1 038 pixels
Display aspect ratio                     : 1.85:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Writing library                          : x264 core 157 r2935 545de2f
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.95:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=32 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.20 / pb_ratio=1.10 / aq=3:0.80
Language                                 : English
Default                                  : Yes
Forced                                   : No
Statistics Tags Issue                    : no_variable_data 1970-01-01 00:00:00 / no_variable_data 2010-02-22 21:41:29
FromStats_BitRate                        : 18940598
FromStats_Duration                       : 01:39:16.117000000
FromStats_FrameCount                     : 142804
FromStats_StreamSize                     : 14101552732
Audio
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Codec ID                                 : A_DTS
Bit rate mode                            : Variable / Constant
Bit rate                                 : Unknown / 1 509 kb/s
Channel(s)                               : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Title                                    : DTS-HD MA 7.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
FromStats_BitRate                        : 5357591
FromStats_Duration                       : 01:39:16.118000000
FromStats_FrameCount                     : 558386
FromStats_StreamSize                     : 3988805972
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : Stripped SRT
Language                                 : English
Default                                  : No
Forced                                   : No
FromStats_BitRate                        : 41
FromStats_Duration                       : 01:27:42.299000000
FromStats_FrameCount                     : 1101
FromStats_StreamSize                     : 27325
Text #2
Format                                   : UTF-8
Title                                    : SDH SRT
Language                                 : English
Default                                  : No
Forced                                   : No
FromStats_BitRate                        : 46
FromStats_Duration                       : 01:36:45.300000000
FromStats_FrameCount                     : 1343
FromStats_StreamSize                     : 33612
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Title                                    : SDH
Language                                 : English
Default                                  : No
Forced                                   : No
FromStats_BitRate                        : 36677
FromStats_Duration                       : 01:36:45.299000000
FromStats_FrameCount                     : 2686
FromStats_StreamSize                     : 26615500
Text #4
Format                                   : PGS
Muxing mode                              : zlib
Language                                 : French
Default                                  : No
Forced                                   : No
FromStats_BitRate                        : 32195
FromStats_Duration                       : 01:31:24.646000000
FromStats_FrameCount                     : 2132
FromStats_StreamSize                     : 22072437
Text #5
Format                                   : PGS
Muxing mode                              : zlib
Language                                 : Spanish
Default                                  : No
Forced                                   : No
FromStats_BitRate                        : 30060
FromStats_FrameCount                     : 2084
FromStats_StreamSize                     : 20608754
Menu
00:00:00.000                             : :Chapter 01
00:08:39.102                             : :Chapter 02
00:16:47.256                             : :Chapter 03
00:25:37.745                             : :Chapter 04
00:34:20.892                             : :Chapter 05
00:43:28.397                             : :Chapter 06
00:48:31.992                             : :Chapter 07
00:56:07.656                             : :Chapter 08
00:59:09.546                             : :Chapter 09
01:04:57.310                             : :Chapter 10
01:11:49.722                             : :Chapter 11
01:18:10.519                             : :Chapter 12
01:22:04.002                             : :Chapter 13
01:30:06.276                             : :Chapter 14
01:39:13.781                             : :Chapter 15
Post by davilla » 10 Feb 2019, 21:49
1st is was an AC3 issue, now EAC3. Are we talking both now ?
Montoya
Post by Montoya » 10 Feb 2019, 22:06
10 Feb 2019, 21:49
I first noticed AC3 issue with Live TV and recordings indeed, but when I mentioned about my sound level testing with dB meter app for the first time, I mentioned both:
Montoya wrote:
10 Feb 2019, 00:48
Live TV AC3 channel vs Recording play of that same channel in MrMC vs play of that same recording in Infuse:
MrMC is approx. 6dB down in peak level when playing the recording, compared to Live TV channel play or Infuse.
Local content, intro clip 20th Century Fox Bohemian Rhapsody (eAC3 or DD+)
MrMC is approx. 9dB down in peak level compared to Infuse during that intro clip. Infuse sounds more spatial and vibrant.
Haven't tested AC3 with latest TF, with Live TV and recordings yet, so I will get back to you.
Montoya
Post by Montoya » 10 Feb 2019, 22:32
Just checked sound levels AC3 with Live TV channels vs recordings and latest TF fixes the AC3 issue.
Sound levels are equal now when Live TV vs recording is compared, so thanks :D
Now only EAC3 is left to fix, so if you need the original file I tested EAC3 with, just let me know.
jpalenz77
Post by jpalenz77 » 11 Feb 2019, 00:34
jpalenz77 wrote:
10 Feb 2019, 13:14
10 Feb 2019, 12:08
10 Feb 2019, 05:37
I can see the same issue... will check it. Thanks
fixed for next TF/beta
Perfect!
Still happening on the new beta
Post by amet » 11 Feb 2019, 03:38
jpalenz77 wrote:
11 Feb 2019, 00:34
jpalenz77 wrote:
10 Feb 2019, 13:14
10 Feb 2019, 12:08
Perfect!
Then we are talking about different issues, i could reproduce before and now issues are fixed.
Explain it to me step by step to try to reproduce here please
Ted377
Post by Ted377 » 11 Feb 2019, 03:40
11 Feb 2019, 03:38
jpalenz77 wrote:
11 Feb 2019, 00:34
jpalenz77 wrote:
10 Feb 2019, 13:14
Perfect!
It works again for me 👍🏼
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 3)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190713.1549)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
