Hue Client - Force Lights ON only after sunset  [SOLVED]
mrmrmrmr
Post by mrmrmrmr » 15 Dec 2018, 09:05
I have enabled "Force Lights ON only after sunset" on Hue client settings.
The system date/time is correct and region is set to Turkey which is also correct.
However, lights are forced to ON midday.
What is it that I am missing ?
thanks.
Re: Hue Client - Force Lights ON only after sunset
Post by davilla » 15 Dec 2018, 16:11
mrmrmrmr wrote:
15 Dec 2018, 09:05
thanks.
Does the time in MrMC match the time in system ?
mrmrmrmr
Post by mrmrmrmr » 15 Dec 2018, 19:31
which two time exactly should I check ?
There's one time on right top corner when I'm in Mrmc menu.
Post by davilla » 15 Dec 2018, 19:34
What time does the system show, that is back out of MrMC and see what time fireOS/Android shows.
mrmrmrmr
Post by mrmrmrmr » 17 Dec 2018, 19:33
they both show the correct local time in GMT+3:00
mrmrmrmr
Post by mrmrmrmr » 25 Dec 2018, 07:52
I tried this now with another Fire TV. (the first one was a Fire TV 4K 3rd gen, this is a Fire TV stick 2nd gen)
it has the same problem.
Fire TV OS time is correct (10:50 - GMT+3)
MrMC app shows correct time (10:50)
But the lights are turned on when "force lights on ONLY after sunset"
what else should I check ?
Re: Hue Client - Force Lights ON only after sunset  [SOLVED]
Post by amet » 25 Dec 2018, 09:42
is hue bridge setup correctly for the sunset? we don't know when the sunset needs to be enabled, we get that info from hue bridge
https://www2.meethue.com/en-us/support/ ... ature-work
mrmrmrmr
Post by mrmrmrmr » 25 Dec 2018, 20:38
I didn't know that. I had thought Mrmc app would get that info from Timezone.
Now I enabled "location" on the hue bridge. Let's hope it fixes the problem.
Post by amet » 26 Dec 2018, 09:24
mrmrmrmr wrote:
25 Dec 2018, 20:38
it works here without any issues, let us know
mrmrmrmr
Post by mrmrmrmr » 05 Jan 2019, 06:34
it is ok now after I set correct location.
thanks.
