in kodi, when I set an individual audio/video setting (subtitles offset, zoom amount)
when I stop the movie and return to it, those settings are saved.
in MRMC, I need to enter them again.
Is there a way to make those setting persistent per movie?
MRMC wont keep individual audio/video settings
Re: MRMC wont keep individual audio/video settings
anyone knows if there is something I can do to fix it?
or its like that and there is no way?
Those should be saved in database, they work fine for me on tvOS ... @koying, are you seeing it on your side
- koying
Yeah, I noticed something like that, but assumed it was due to current development and planned to check later.
Will investigate...
Will investigate...
thanks for checking. I find it really necessary and I think others too.
hi, any progress with this issue?
thanks
thanks
Don't know if something changed but this issue is now fixed.
