nvidia shield atmos audio - bug with channel mapping?
orenmi
Post by orenmi » 15 Dec 2018, 07:33
hi,
sometimes, in 4K dolby atmos movies, the sound suddenly start coming ALL from one random speaker.
restarting the movie fix it. sometimes the bug comes back after a few minutes, and sometimes its remains ok till the end.
Does anyone experience this too? is there a solution?
orenmi
Re: nvidia shield atmos audio - bug with channel mapping?
Post by orenmi » 15 Dec 2018, 07:46
(please move this to the nvidia shield forum)
orenmi
Post by orenmi » 04 Feb 2019, 08:47
still happening, almost every 4k atmos movie I watch, about 20 minutes into the movie, suddenly some channels are missing, (like no center anymore) or all channels are coming out of the right surround speaker etc.
stopping and resuming the movie fix it.
Post by amet » 04 Feb 2019, 11:27
Debuglog please so @koying can try to pin point the issue
Post by koying » 04 Feb 2019, 15:44
I assume this is passthrough, right? IEC?
If so, as MrMC, by definition, doesn't touch the actual "sound", I'd suggest to check whether there would be an issue in the source file or the AVR.
orenmi
Post by orenmi » 04 Feb 2019, 15:51
using passthrough, yes.
I know the player should not touch the sound on this case, but I cant think of anything that can act like this.
its a new Denon 3400 and new cables.
If it happens and restarting the movie always fix it, it seems to me like its a software thing.
Or, there is an issue with Nvidia shield. But I wonder what in the hardware can cause that.
hieyemtim
Post by hieyemtim » 05 Feb 2019, 17:49
Hi Koying. Im having the same issue. All these files have been working perfectly with SPMC. It’s so sad because I want to use MRMC but I have to keep going back to your amazing SPMC.
hieyemtim
Post by hieyemtim » 05 Feb 2019, 17:59
I have a Pioneer Elite receiver and everything is up to date as far as firmware and software. SPMC is set to Android RAW passthrough and works every time. SPMC is only having these issues.
Post by davilla » 05 Feb 2019, 20:31
hieyemtim wrote:
05 Feb 2019, 17:59
Is MrMC also set to use RAW ?
orenmi
Post by orenmi » 12 Feb 2019, 10:41
if I'm unchecking the IEC checkbox (i guess this puts it at RAW?) I get no sound at all.
