Manual Emby Login with https
gnollo
Re: Manual Emby Login with https
Post by gnollo » 03 Feb 2019, 19:44
Correct. Not sure how that doesn't work, and I still can connect using the Emby app and Kodi with the EmbyCon plugin...
gnollo
Post by gnollo » 07 Feb 2019, 13:12
Fixed by removing all my existing setup and going via Cloudflare as per guide. I now have external access to my emby server again.
Montoya
Post by Montoya » 07 Feb 2019, 14:50
Excellent :-)
Case closed, so Devs can mark this topic as solved ;)
Apple TV 4K 64GB tvOS 12.1.2, Win10 Pro x64 1809 build17763.379
TVMosaic server build 17051, Emby server build 4.1.0.16 beta
