Cant exit from playlists Topic is solved
Waltman
Post by Waltman » 28 Nov 2018, 19:56
On Apple tv. When in playlist, neither menu or the go back .. enable you to get back to the main menu. You are stuck in this screen
pecinko
Re: Cant exit from playlists
Post by pecinko » 28 Nov 2018, 21:33
This might be a problem with Mrmc, not necessarily skin related. @amet ?
eddiestrike
Post by eddiestrike » 19 Dec 2018, 10:59
I also have this problem. I must force exit the MrMc and relaunch
Post by amet » 19 Dec 2018, 15:29
Fixed in 3.7.1
