No scrubber on recorded tv
garyd123
Post by garyd123 » 28 Oct 2018, 06:58
Hi, I cannot scrub through the videos tvheadend records. Is there a trick to this?
I have tried both Siri mode on and off for the remote in the input menu.
Re: No scrubber on recorded tv
Post by davilla » 28 Oct 2018, 12:45
garyd123 wrote:
28 Oct 2018, 06:58
The scrubber is not supported on pvr sources.
garyd123
Post by garyd123 » 29 Oct 2018, 09:55
It also doesn't work if I map an NFS share to my recordings. Any reason?
The files scrub fine in other apps.
Post by davilla » 29 Oct 2018, 11:30
garyd123 wrote:
29 Oct 2018, 09:55
Maybe you have it turned off ? works here.
Post by cosmoxl » 30 Oct 2018, 00:16
29 Oct 2018, 11:30
garyd123 wrote:
29 Oct 2018, 09:55
My tv recordings (mpeg2 in .ts) are hit and miss - some have the scrubber, some don't.
Post by davilla » 30 Oct 2018, 14:00
cosmoxl wrote:
30 Oct 2018, 00:16
29 Oct 2018, 11:30
garyd123 wrote:
29 Oct 2018, 09:55
debuglog on a hit and miss :)
Post by cosmoxl » 30 Oct 2018, 15:08
30 Oct 2018, 14:00
cosmoxl wrote:
30 Oct 2018, 00:16
29 Oct 2018, 11:30
anything in particular in logging settings that needs to be enabled besides debug logging?
Post by davilla » 30 Oct 2018, 15:52
cosmoxl wrote:
30 Oct 2018, 15:08
30 Oct 2018, 14:00
cosmoxl wrote:
30 Oct 2018, 00:16
just enable debug logging.
Montoya
Post by Montoya » 30 Oct 2018, 16:51
cosmoxl wrote:
30 Oct 2018, 00:16
Noticed this too.
When I access my DVBLink and TVMosaic recordings via SMB, that miss percentage is at least 80% and can't find any logic what triggers it, because recordings from same channel (same video/audio codecs) sometimes have scrubber, but mostly not or appears only after x seconds when on pause.
Apple TV 4K 64GB tvOS 12.3 - Win10 Pro x64 1903 build 18362.264
