Plex Addon Transcode Issue
racas78
Post by racas78 » 12 Jun 2018, 22:09
in Plex add-on when I play some file Plex transcode them. I can correct play other Hvc HDR 7.1 mkv, I got the issue just with few movies.
No problem at all if I play the file in MrMc using Plex service.
Can you help me?
Re: Plex Addon Transcode Issue
Post by davilla » 12 Jun 2018, 22:12
if you help us :) debuglog please
racas78
Post by racas78 » 13 Jun 2018, 09:27
Sure, here
Hope is enough
<script src="https://pastebin.com/embed_js/vptgSU9p"></script>
Post by davilla » 13 Jun 2018, 12:19
Looks like something with audio is triggering transcode.
Make sure that the Plex Extension settings are setup correctly. Don't transcode HEVC, etc.
racas78
Post by racas78 » 13 Jun 2018, 12:27
My setup:
Local quality: original
Allow direct play: yes
Allo direct stream: yes
Allow 4K: yes
Allow Hevc: yes
Is there any other step to setup?
Post by davilla » 13 Jun 2018, 12:44
try the built in plex client.
also mediainfo on one of the media files that is getting transcoded.
racas78
Post by racas78 » 13 Jun 2018, 13:12
Yes files are playing good using built in Plex client. I guess the issue happen when I play, using add-on, movies with a HDR/Dolby vision layer.
That's not a problem to me, I can wait the new Ariana Skin and using the built in client.
Thanks for helping
