Dolby Vision
mrbuie2k
Re: Dolby Vision
Post by mrbuie2k » 27 Feb 2019, 22:18
Grencola wrote:
20 Feb 2019, 14:36
I made a little program....
Thanks for this! It does indeed work (on my LG OLED, but not my LG LCD UHD)
My only feedback -
* The original file name gets changed. For the 1st 1 tried, I forgot the original filename and had to re rip
(no big problem, just hoping that can change)
* As noted, have to bring file to local PC, run program, then return to my DLNA server (again, no big deal)
* Also as noted, would be nice to get the Atmos tracks added
FYI, I'm using my TV's built in DLNA client and have been successful with at least 5 movies so far.
Thanks again.
Grencola
Re: Dolby Vision
Post by Grencola » 28 Feb 2019, 05:00
mrbuie2k wrote:
27 Feb 2019, 22:18
Grencola wrote:
20 Feb 2019, 14:36
My only feedback -
Thanks again.
Glad you like it!
I finally got home and had a few mins to work on it. I made the following changes:
-original filename is kept intact
-support for smb / network shares
unfortunately I can't add an atmos track unless someone has a licensed copy of Dolby Media Encoder Suite they're willing to share..
as always, for best results make sure the single m2ts / mkv file to be converted is in a folder all by itself.
I'll work on batch support for multiple files when I get more time.
new links:
m2ts-mp4: https://bit.ly/2NDaNP3
mkv-mp4: https://bit.ly/2SEo5fc
cheers! :)
ryu4000
Re: Dolby Vision
Post by ryu4000 » 02 Mar 2019, 05:21
Can't get the program to work. This what i did pointed to my mkv files its the only file in the folder and press install the black box pops up says something 30mins then it quickly done and im left with my file being changed from it's name but it still says mkv not mp4.
Grencola
Re: Dolby Vision
Post by Grencola » 02 Mar 2019, 06:09
ryu4000 wrote:
02 Mar 2019, 05:21
oh shoot. thx for the bug, m2ts-mp4 was fine it was just a bad line in mkv-mp4. try it now..
new mkv-mp4: https://bit.ly/2Y31koZ
Grencola
Re: Dolby Vision
Post by Grencola » 02 Mar 2019, 06:25
20 Feb 2019, 17:46
source code ?
@echo Unpacking temp files... Done!
@echo OFF
for %%a in ("*.m2ts") do @echo %%~na> filename.txt
ren *.m2ts Movie.m2ts
@echo Found M2TS File! Extracting tracks, please wait (approx. 30 mins)...
@echo OFF
eac3to.exe Movie.m2ts 1: bl.hevc 2: el.hevc 3: audio.ac3 -core -640
@echo Muxing tracks to MP4, please wait (approx. 45 mins)...
@echo OFF
mp4muxer_64bits.exe --dv-profile 7 -i bl.hevc -i el.hevc -i audio.ac3 --media-lang eng -o DV-Movie.mp4
set /p texte=< filename.txt
ren Movie.m2ts %texte%.m2ts
ren DV-Movie.mp4 %texte%.Dolby.Vision.mp4
echo y | del *.dll *.txt *.exe *.cmd *.hevc *.ac3
I typed that into a txt file and renamed it m2ts.cmd, then my winrar .exe 'program' simply just auto-extracts it along with eac3to app contents, and mp4muxer.exe into the chosen directory and auto-runs the .cmd file :) pretty basic but it gets the job done.
sm0ke83
Re: Dolby Vision
Post by sm0ke83 » 02 Mar 2019, 14:02
Thnx for the update! Will try within a few days (little time at the moment).
I used your commands from the m2ts.cmd manually, since I prefer using 2 disks (one for read, one for write). Also found workaround for smb-share: Just map networkdrive in explorer :P
In my case remuxed mkv's (with DV layer) stutters continiously, the output file is not viewable at all. When using m2ts file with same movie (Blu-ray release with DV-layer, not remux with DV-layer), output works like a charm.
Also tried creating different files using different DV-profiles (using the --dv-profile option), but ouput files are all the same??
Wanted to try profile 8, as it is supposed to be single layer and closest to profile 7 (according to Dolby documentation, page 9).
https://www.dolby.com/us/en/technologie ... levels.pdf
Thnx & Keep up the good work!
ryu4000
Re: Dolby Vision
Post by ryu4000 » 02 Mar 2019, 16:21
Grencola wrote:
02 Mar 2019, 06:09
ryu4000 wrote:
02 Mar 2019, 05:21
new mkv-mp4: https://bit.ly/2SymgQQ
Now nothing poping up now just installs a bunch of files in the folder with the mkv.
Grencola
Re: Dolby Vision
Post by Grencola » 02 Mar 2019, 19:47
ryu4000 wrote:
02 Mar 2019, 16:21
last time, I swear! literally just needed to put two % symbols where I only had 1 before because it's in a script. sorry I'm not the best coder :(
ryu4000
Re: Dolby Vision
Post by ryu4000 » 03 Mar 2019, 00:07
Grencola wrote:
02 Mar 2019, 19:47
ryu4000 wrote:
02 Mar 2019, 16:21
working mkv-mp4: https://bit.ly/2SEo5fc
We get it right in due time.New update this one does like the first one did me it opens then quickly close the dos window.It renames the movie to movie but after that stays as mkv no mp4 output.
Grencola
Re: Dolby Vision
Post by Grencola » 03 Mar 2019, 05:53
ryu4000 wrote:
03 Mar 2019, 00:07
are you sure you downloaded the latest one? because I just tried it and it worked perfectly. took about 1h 12m. to minimize confusion I replaced all instances of the app's url in my comments with the latest version.
