There is a setting to 'allow file renaming and deletion' from within the application, which is great, except that it leaves either a mismatch of file/folder names on 'rename' or empty folders on 'delete' if, like me, your files are stored in separate folders with matching titles.
Would it be possible to create a sub-option to rename/delete the containing folder if the names match?
I'm not sure how many people store their files in this way, so it may not be too popular an option but it would certainly help me
Thanks for your help.
Rick.
