Hello
Introduce yourself here
Fennec
Hello
Post by Fennec » 03 Jun 2018, 03:17
Hi, just signed up. Don't know much about MrMC, but saw it on the Play Store and bought it anyway.
What are some of the differences between Kodi and MrMC?
I use an Android Shield TV---occasionally.
I assume MrMC will work well with that device and 4K HDR10 rips?
Any plans to implement HDR to SDR? I know MPV and I *think* MPC-HC with madVR can do this.
Re: Hello
Post by cosmoxl » 03 Jun 2018, 03:21
Fennec wrote:
03 Jun 2018, 03:17
The main difference is no user installed addons.
Yep, it'll play HDR material just fine. But, no tonemapping, yet. Yes, mpv can do tonemapping with some custom settings. So can madvr.
