Nebula skin
Introduce yourself here
Batmanbernix
Nebula skin
Post by Batmanbernix » 29 May 2018, 07:08
Hello,
I bought MrMC yesterday and it seems to be fine.
In the past, I used SPMC on Shield and I customize my interface with Nebula skin.
On MrMC, it seems there is no way to add Nebula skin. Is it possible to add Nebula ?
Best regards
Re: Nebula skin
Post by amet » 29 May 2018, 15:58
Nope, like we said few times... no user installable addons... and skin is an addon
AlexBlomkvist
Re: Nebula skin
Post by AlexBlomkvist » 17 Jun 2018, 17:26
29 May 2018, 15:58
I have actually also used Nebula on SPMC for years and, although I can live without it, it would be nice to have it as an option. Now, I perfectly understand that myself, as a user, cannot add any addons, but can't you build this addon in the app then?
If not, I assume this is a NO only because that would add-up to the size of the app without bringing you any benefit since there's just a few of us actually asking for it, is that right?
Thank you.
Re: Nebula skin
Post by koying » 18 Jun 2018, 08:46
Nebula seems very similar to our forthcoming Ariana skin ;)
