wrxtasy
Re: Testing MrMC 3.7.0 - [Invites Closed]
Post by wrxtasy » 17 Aug 2018, 09:02
koying wrote:
17 Aug 2018, 08:58
With latest test?
Pretty sure I had this issue earlier but that it was fixed....
This version as per the log posted above:
Starting MrMC (3.7-0 Git:2018-08-01-229b3bb)
Post by davilla » 17 Aug 2018, 15:52
missing thumb issue reproduced.
SUPERBIF
Post by SUPERBIF » 18 Aug 2018, 07:42
Hi when will we be able to get invited to TF on Android again. Have sent mail long time ago.
I think it was overkill to make a new thread just for this question:)
Post by amet » 18 Aug 2018, 09:16
SUPERBIF wrote:
18 Aug 2018, 07:42
testflight invites are closed, once its open again you can send the e-mail again
Post by cosmoxl » 18 Aug 2018, 16:10
Got the update for Shield overnight though it was build August 3. 677d63e is the code.
Regarding the problem of plex client.
Here is the log from starting up MrMC and waiting a bit to see if my plex server loads.
https://paste2.org/CP7EZs7s
And here is the log after I go into services>plex and click on my username. When I go back to the home screen my plex server is then loaded up, all appears well, though I do see many errors in the log.
https://paste2.org/w0WhHtd1
SUPERBIF
Post by SUPERBIF » 18 Aug 2018, 16:46
18 Aug 2018, 09:16
SUPERBIF wrote:
18 Aug 2018, 07:42
Okay thanks
Post by amet » 18 Aug 2018, 17:00
cosmoxl wrote:
18 Aug 2018, 16:10
what happens when you hit "http://192.168.2.10:32400/identity" from a browser? thats really odd, any plex server responds to that
Post by cosmoxl » 18 Aug 2018, 17:30
18 Aug 2018, 17:00
cosmoxl wrote:
18 Aug 2018, 16:10
If I hit http, I get connection was reset error. If I hit https I get an xml page with
<MediaContainer size="0" machineIdentifier="removed numbers and letters just in case they are private" version="1.13.5.5291-6fa5e50a8">
</MediaContainer>
Post by timstephens24 » 18 Aug 2018, 17:37
Do you have (in Plex) 'Settings -> Network -> Secure Connections = Preferred' or is it set to required?
Post by cosmoxl » 18 Aug 2018, 18:22
timstephens24 wrote:
18 Aug 2018, 17:37
required. and it's staying that way. :)
