Playing from my HDD - Nvidia Shield
Introduce yourself here
hgny123
Post by hgny123 » 01 May 2018, 06:58
Hi all!
Purchased MrMC for my shield tv and love it!
I have an external HDD that i plugged to my shield with plenty of movies and tv show's, but i dont have an access through MrMC.
So. My question is how do i get an access to my HDD?
Thanks!
Re: Playing from my HDD - Nvidia Shield
Post by koying » 01 May 2018, 08:23
You don't see your HDD listed in "Videos-Files" ?
Can you see it via, eg, X-plore (https://play.google.com/store/apps/deta ... lore&hl=fr) ?
hgny123
Post by hgny123 » 01 May 2018, 08:28
I do see it in video files, but can not enter it. It says that the source have been moved or something like this. I can take a photo when i will back home.
Post by koying » 01 May 2018, 08:51
Ok. Please also test if you can enter via X-plore.
It could be that the format of your HDD is not supported by shield (NTFS?)
hgny123
Post by hgny123 » 01 May 2018, 08:59
I can access it via x-plore kodi and spmc. I searched in the forum and saw that storage permission isn't prompt automatically, so i will chack that issu and will updae if that was the problem.
hgny123
Post by hgny123 » 01 May 2018, 12:01
Indeed, permissions problem, had to check the storage permission in settings of shield.
alphabetagaga
Post by alphabetagaga » 10 Aug 2018, 16:59
hi guys
i'm having a similar problem. on mrmc lite i go to
media sources > video
my hdd (elements) shows up above 'add videos' and click on it and get 'remote share - path not found or invalid'
my hdd shows up in x-plore and have been using it with kodi/spmc. any suggestions?
thanks a lot
alphabetagaga
Post by alphabetagaga » 10 Aug 2018, 17:21
it's ok i found it :) i thought there was something in
shield settings > storage & reset
that i had to enable storage access for but it was actually under
shield settings > apps > mrmc lite > permission
