Issue when adjusting display rate
mmihai
Post by mmihai » 27 Apr 2018, 21:09
Hi
I am using ATV 4K with Mrmc. When selecting the option to "adjust display rate", then the video file is automatically fast forwarding when opened.
Notes:
- 100% this is not because of accidental swipes; I used also a normal remote, same issue appears.
- When deselecting the option - the issue disappears.
- The amount of forward seeking is variable - 10 minutes for longer samples, couple of seconds for shorter ones.
debuglog: https://pastebin.com/T0FFpUKV
Thanks for any idea on how to fix this!
Re: Issue when adjusting display rate
Post by davilla » 28 Apr 2018, 12:49
something told it to seek;
DEBUG: demuxer seek to: 15979.000000 (ms)
How long is your display timeout on adjusting display ?
mmihai
Post by mmihai » 28 Apr 2018, 18:21
Hi
1. It is set at 4 sec - the default value.
What I also tried (no change means there is an automated seek after switching the refresh rate). I used the TV remote - non-touch - to control ATV (through CEC)
1 - reset MRMC video / audio playback to default - no change
2 - disabled ARC - no change.
3 - used SMB / NFS and both option (libsmbx and the other one) - no change
4 - reset ATV video and audio settings to default - no change
5 - set ATV to 4K / 1080p / HDR / SDR - no change.
6 - set the TV to game mode - no change.
7 - used various file types / containers: x264 / x265 in mp4 / m2ts / mkv - no change.
8 - disabled CEC on TV and ATV - no change.
9 - Disabled "match frame rate" in ATV while option enabled in MRMC- perfect result, no seek.
The seek value _appears_ to be cca 10% the length of video file played, capped at 10 minutes.
mmihai
Post by mmihai » 30 Apr 2018, 21:29
some more findings:
1 - if the "always adjust display rate" option is not selected, then ATV will not switch from HDR to SDR (for SDR sources), even if "Match Range" is selected in tvos (11.2 here).
2 - if VTB is selected, then the colors for SDR material are washed out; if VTB is not selected then the colors are correct.
I used Infuse as a control test - no issues on playback / switching / colors - this is to eliminate culprits such as bad cable / TV issues. Something is wrong with my setup and I cannot figure what it is :cry:
___
Later edit: if I set the apple tv to resolutions other than 1080p and 4k, such as 720p, 1050p, 900p, then the issue is gone.
mmihai
Post by mmihai » 03 May 2018, 19:22
just to provide some closure: I found the issue in the end :)
Post by cosmoxl » 03 May 2018, 19:27
mmihai wrote:
03 May 2018, 19:22
well do tell what it was!
mmihai
Post by mmihai » 03 May 2018, 19:30
I took the batteries out of the TV smart remote (Samsung MU 6300) and then the issue disappeared.
I put the batteries back - the seek issue was back. So Davilla was right - someone was telling it to seek :). That remote is sending an "up" when playing a video, which explains the 10 minutes search.
