Trakt stopped working after latest 3.6.1 update
Any issues relating to https://trakt.tv service
Re: Trakt stopped working after latest 3.6.1 update
Post by koying » 26 Apr 2018, 06:09
We really need to understand what's happening on the trakt website side:
- You press signin in mrmc
- you get the invitation to go to "https://trakt.tv/activate"
- you get the prompt on trakt website to enter the code that mrmc is showing
What happens next?
I just tried on android and it works for me
You mentionned being "already logged in". Are you using the correct url, with "/activate"?
DopedAngel
Post by DopedAngel » 26 Apr 2018, 09:17
koying wrote:
26 Apr 2018, 06:09
What happens next?
I don't get the invitation that I can go and enter in trakt.tv I am stuck at the bolded part I get no response after pressing the sign in so I don't get a code to enter into the website. trakt client was logged earlier and everything was fine till I updated to 3.6.1 though I am guessing this with the trakt website by checking the last episode that was set as watched. For an unrelated reason I had to reset my nvidia shield after I posted the log. But I am getting the same error with a fresh install of mrmc on factory reset device.
Post by amet » 26 Apr 2018, 09:46
I see the issue is on black glass nova skin
19:30:39 T:138100630608   ERROR: unable to load:/mnt/expand/1ad18aec-c5f8-45a6-9705-415e8969ef2d/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.blackglassnova/1080i/DialogProgress.xml, Line 0
                                            Failed to open file
you should not have that issue on Opacity or any other skin, do you?
Post by amet » 26 Apr 2018, 09:48
26 Apr 2018, 09:46
                                            Failed to open file
@Tgxcorporation is this intentional?
DopedAngel
Post by DopedAngel » 26 Apr 2018, 10:24
26 Apr 2018, 09:46
                                            Failed to open file
Nice catch this solved my problem. I was just about to set it up for the taking log but read your message first
Post by amet » 26 Apr 2018, 10:40
DopedAngel wrote:
26 Apr 2018, 10:24
26 Apr 2018, 09:46
                                            Failed to open file
great, thanks for letting us know about this issue.... we'll make sure we get it fixed for next version
Tgxcorporation
Post by Tgxcorporation » 26 Apr 2018, 14:18
I've just added the missing file in the blackglassnova repository.
Sorry!
Tgx
Post by amet » 26 Apr 2018, 15:17
Tgxcorporation wrote:
26 Apr 2018, 14:18
Sorry!
Tgx
Thanks Tgx
