MythTV, guide data
sfatula
MythTV, guide data
Post by sfatula » 11 Apr 2018, 06:06
If I run mrmc on iPad pro, it gives slightly annoying messages for each timer on the bottom, wish it didn’t but it does. However, no guide data is downloaded. If I go to home screen and come back, still no guide. If I force quit and then run again, I get the annoying timer displays but now also that it is downloading guide info.
So, essentially, I have to run the app twice to get guide data. Seems like a bug? Maybe it does not happen in the full version, just trying it out first. Almost certainly will purchase.
Loving the app overall! Fantastic. I would be able to watch all mythtv recordings, live tv (and since it’s via myth tuner locks apply which is great), and the latest plex integration is great.
Addendum - the exact same thing happens with AppleTV version as far as no guide data. I found a setting to turn off display of timer messages so that annoyance is gone.
So, the problem is the guide is empty on the first execution of the app.
jrh3us
Re: MythTV, guide data
Post by jrh3us » 15 Jul 2018, 15:13
I too am also seeing this issue, using Mythtv .29. the Kodi add on for mythtv guide data works fine.
Thanks in advance!
ddempsey3
Post by ddempsey3 » 03 Sep 2018, 21:34
I am seeing the exact same behavior. The guide data is not shown. I have a Kodi client and regular mythfrontend working fine.
What logs do you need?
zeusremi
Post by zeusremi » 29 Jul 2019, 01:35
When will this get fixed. The mythtv pvr works fine in Kodi 17.6. Mrmc just needs to download the guide data the same way. I noticed if I use HDHomeRun pvr I have guide data. So it’s gotta be something with the mythv pvr extension. I almost love this app if it just had the guide data for mythtv hdhomerun.
