At a high level, my setup is having a Master Profile and Kids Profile. Hopefully this isn't too unusual for other users with kids in the family? I am open to suggestions, this is just what I can up with.....
I then map my 4 NAS Shares accordingly. Well technically one NFS share called videos with the four folders noted below....
tv and movies folders are sources for the Master Profile
kids_tv and kids_movies are the sources for the Kids Profile
While under master profile, I added the /video/tv as the TV source and then added /video/movies as the Movie source. These both showed up fine in the main menu first two items Movies and TV Shows.
I basically did the same thing under the Kids profile. I added the /video/kids_tv as the TV source and then added /video/kids_movies as the Movie source. The Movies showed up fine in the kids profile, but the TV shows is not showing here. Maybe user error and I should try again? Else I need to manually add TV Shows within settings/appearance?
TV Show Menu Option Missing from Kids Profile
Prodeje79
Re: TV Show Menu Option Missing from Kids Profile
It definitely appears I added it correct and labeled it to use the TV DB. Still not showing the TV shows in Kids Profile. Any ideas?
Prodeje79
I tried my upstairs TV, same issue. I noticed the TV DB scan was failing. Odd.
I went ahead and rebooted cable modem and router. Scans appeared to work this time and now showing TV shows in menu! I guess I am good now. Still awaiting response for my question in Trakt section.
I wish I could help you with Trakt but I've never used it.Prodeje79 wrote: 26 Mar 2018, 22:19 I tried my upstairs TV, same issue. I noticed the TV DB scan was failing. Odd.
maybe a debuglog might show more info.
Prodeje79
I'm good now. TV db was I connecting on either box. Rebooted modem.and router . Tvdb scanned and tv shows added ok. Now please see my question in trakt section so I can get started.
