Fanart on season-level
pauabaer
Post by pauabaer »
Hi guys,
i am using the amber Skin on an ATV4K with the embyclient. Works fine. But I've noticed that in the tv shows section on the season-level the fanart is missing. Means when i navigate from the mainmenu to tv shows, then enter one and choose for example the first season there are listed all of the episodes but the background is black. Would be nice if there is shown the season/tv show-fanart.
Similar issue in the movie section. But here would it be nice if you can see the fanart on the first level in the "symbol viewmode".
Do you think its possible to be shown like this?
greez
pauabaer
Re: Fanart on season-level
Opacity skin has this , have you played with all artwork adjustments in skin settings?
