[How-to] mrmc.log
Please, only How to's in here. No questions or support, use appropriate subsection for that
[How-to] mrmc.log
Post by amet » 13 Jan 2016, 04:05
This is available on version 1.2.0+ only, update is available on App store
enable debuging
Settings > System > Logging > Enabled Debug Logging
enable webserver
Settings > Services > Web Server > Allow Remote control via HTTP
get the log from MrMC webiterface and paste it to pastebin.com, please do not paste any logs into the forum posts.
http://{AppleTV_IP}:8080
if mrmc.old.log is required, you can get it by manually entering its URL in web browser.
http://{AppleTV_IP}:8080/vfs%2Fspecial%3A%2F%2Flogs%2Fmrmc.old.log
edit: corrected using below comments
jabohn
Re: [How-to] mrmc.log
Post by jabohn » 17 Jan 2016, 03:08
I think this is wrong.
There is no Settings > System > Debug
Debugging is under Settings > System > Logging > Enabled Debug Logging
There is no Settings > System > Services > Allow Remote control via HTTP
It's just Settings > Services > Web Server > Allow Remote control via HTTP
Please correct me if I'm wrong or otherwise correct the original How To. Thanks.
Post by davilla » 19 Mar 2016, 16:42
to get mrmc.old.log, which is the previous runtime log :
http://<atv4s IP>:8080/vfs%2Fspecial%3A%2F%2Flogs%2Fmrmc.old.log
jbennett
Post by jbennett » 25 Aug 2016, 17:40
Here's a tip (probably AFTV-specific) for another way to access mrmc.log files without using the web interface:
In MrMC's File manager, click "Add source" and enter the following path:
/sdcard/Android/data/tv.mrmc.mrmc/files/.mrmc/temp
...and click "OK" to save. You'll see the new source "temp" listed in File manager, under which you'll find the mrmc.log and mrmc.old.log files, which can then be copied wherever you like (USB drive, micro SD card, network share, etc., etc.).
