Subtitels Forced Only
Any issues relating to subtitle search and download function
Ekomax
Post by Ekomax » 21 Dec 2015, 09:12
Hi, i'm using this great app from the start and i like it really. Used Plex and Infuse, DS Video on my ATV4 with my Ds216play but MrMc ist the best for me.
My problem is that i dont know how to activate forced only subtitles. For example i watch the movie "The Mummy" and download the subtitle via opensubtitles.org. This works fine. But if i avtivate subtitels during watching over the menu then i have subtitels all the time not just "forced only" .
Can someone help?
Best regards and keep up the goog work.
Re: Subtitels Forced Only
Post by amet » 21 Dec 2015, 10:18
it really is a matter of finding a correct subtitles to download, some will have a "forced" flag to it.
we don't get to search for forced only, we get a list of all :)
Forced flag that is used in settings is for embedded forced subtitles, external subs are all treated the same... as normal subs.
I know it doesn't help you much but those are the limitations of subtitle providers.
Ekomax
Post by Ekomax » 21 Dec 2015, 10:51
thank you very much. keep up the good work.
XX_Keo_XX
Post by XX_Keo_XX » 02 Mar 2016, 06:40
I know my movie has embedded subtitles in it. It plays fine in Plex, but MrMC is either all on or off. I tried to find a forced subtitle for my movie, but it had type-o's in it and they are driving me nuts! Any way to use the subtitles embedded within my movie?
Can someone help me understand why Plex plays them fine but MrMC requires an external file?
