No display the information of the film
kune28
Post by kune28 »
Hello and congratulations on the application. I have my database in mysql, and as I put in the settings, when I select a chapter of a TV Show the information appears and then I select reproduce, but movies do not happen that, when I select a movie, the information does not appear, directly it is playing.
If I select the submenu on the film, various options appear but not to display information.
kune28
Re: No display the information of the film
Post by kune28 »
Hello, I tested if I disable mysql data, and add sources of movies that are located on the same computer for SMB that the MySQL database server, the library is scanned and to select a movie information appears.
Remove the local source, and back to enable mysql, and continues to fail, not the film library is scanned and no shows the information of the selected movie, but the series yes scanned and show the information
