I do agree, reverted back to white
testing MrMC 3.2.0
Re: testing MrMC 3.2.0
Davilla, were you able to reproduce the bug on your side with the movie sample I provided?Lollypop wrote: ↑15 Oct 2017, 06:30That was a recording. Here is actual movie sample with both audio and video streams:
https://www.dropbox.com/s/2y8g7j2xfxxkg ... e.mkv?dl=0
Cheers
I have to get on a fast net to download the sample. Should be able to fetch it in a few hours. Tell me how you have MrMC audio and tvOS audio setup so I can match it.Lollypop wrote: ↑16 Oct 2017, 13:40Davilla, were you able to reproduce the bug on your side with the movie sample I provided?Lollypop wrote: ↑15 Oct 2017, 06:30That was a recording. Here is actual movie sample with both audio and video streams:
Cheers
I have apple tv audio set to: Video and Audio > Surround Sound and Best Quality Available and on MrMc, I have default settings where passthrough is turned off.davilla wrote: ↑16 Oct 2017, 13:43I have to get on a fast net to download the sample. Should be able to fetch it in a few hours. Tell me how you have MrMC audio and tvOS audio setup so I can match it.Lollypop wrote: ↑16 Oct 2017, 13:40Davilla, were you able to reproduce the bug on your side with the movie sample I provided?Lollypop wrote: ↑15 Oct 2017, 06:30
Cheers
When i roll back to 3.1.0 app store version with these settings the audio plays fine but with the latest testflight, they audio is messed up.
Issue reproduced. Looks like an easy fix.Lollypop wrote: ↑16 Oct 2017, 13:48I have apple tv audio set to: Video and Audio > Surround Sound and Best Quality Available and on MrMc, I have default settings where passthrough is turned off.
(20171016-2f4f6f1)
darwin: audiotoolbox. refactor 14 byte paddign fix to only adjust if a 14 byte padding is detected, let everything else pass unchanged
skin.opacity: Revert "colorize focus texture with primary_color"
- timstephens24
Need actual filename so I can pull it down. As I've mentioned before, I think the real issue is an ffmpeg or mkvmerge issue and we are trying to do a detect/work-around. Some hevc/hdr are scaled right, some are wrong.timstephens24 wrote: ↑16 Oct 2017, 22:33 Subtitles for X-Men Apocalypse were still grey.
https://pastebin.com/5tRYs7zv
- timstephens24
'X-Men Apocalypse (2016) - 2160p HEVC HDR UHD Remux Atmos TrueHD 7.1.mkv'
I can share the file with you over Google Drive, but I didn't use usenet or torrents for it.
