Mediadata/fanart for not detected movies
Egscholten
Post by Egscholten »
I've got a library with a lot of unmatched mediadata. How can I manually choose the right movies? In kodi this coulissen easily be done.
Verzonden vanaf mijn iPhone met Tapatalk
titi91
Re: Mediadata/fanart for not detected movies
Post by titi91 »
Same for me.
60% of the movies where not having a fanart and movie description, I need to adjust them manually but it is easy :
- Place cursor on the movie name,
- Press and stay pressed on the Apple TV4 remote control, in the central pannel,
- A window will appear with multiple options. Options to releoad the fanart and movie description is : Movie Information followed by Refresh (sorry but i am using a French UI so not sure if the translation I made is correct).
Hope that helps.
