emby: added new native emby client
plex: fixed 3D SBS detection
core, added audio silence factor selector
core: remove ".." from root mediawindows that contain services
core: reduce READ_CACHE_CHUNK_SIZE from 512k to 128k
mysql: add SETTING_MYSQL_TIMEOUT setting to MySQL service
homeshelf: various fixes and additions
lighteffect: handle screensaver on/off
fixed: OS screensaver for droid
changed: auto close OSD after 3 sec inactivity
changed: allow xxx.filepart video extension
MrMC v3.0.3 on tvOS
three6zerocool
Re: MrMC v3.0.3 on tvOS
I am having issues trying to get native emby client working.
Can not connect to my Emby server via manual ot token method.
Just says error about Plex token.
I can connect to Emby server (Mac version) using native TVOS Emby app.
Can also connect no problem from iOS Emby app on my iPad.
However, am getting nowhere fast on MrMC Emby configuration on TVOS.
If I use the token option, and visit the Emby site, it says it accepted my pin, and then MrMC displays a connecting message with percent counting up. A few minutes later, it gets to 100%, and then gives error about unable to get token.
If I use the manual option, I get same token error message.
Do you guys think it is because I am using Mac version of the Emby server?
debuglog please
Also describe (in detail) how your emby server is setup. http ? https ? etc.
Emby SignIn by Pin:
Select in settings, a dialog appears with a timeout percent count down. In that dialog is an Emby Pin, enter that pin at https://emby.media/pin.html. Submit and if accepted, then wait for MrMC to fetch and handshake with the Emby Server.
Emby SignIn by UserName:
This is local, by broadcast only. Select in settings, dialog appears. Go to browse. Select the emby server. There might be double entires for local and wan. Local means use local address, Wan means use the internet (global) address. Enter username (and password if needed). click ok.
Emby SignIn by Pin:
- moonrak
Good job! I was waiting for "changed: auto close OSD after 3 sec inactivity".davilla wrote: 27 Apr 2017, 20:47 emby: added new native emby client
Much better now with this feature.
moonrak
Sanjuro
I have to agree with this. Just making my first use of MrMC with this function in place: so simple, and so necessary. Good job.
