EPG Downloader  [SOLVED]
Ted377
EPG Downloader
Post by Ted377 » 26 Apr 2017, 14:26
Hey 🤘🏼
Is it possible to insert this Addon into MrMC ?
Rytec EPG Downloader
That would be nice 😁
THX
Ted377
Re: EPG Downloader
Post by Ted377 » 26 Apr 2017, 17:50
It only serves to update the EPG information. No more and no less.
Ted377
Re: EPG Downloader
Post by Ted377 » 25 May 2017, 13:38
Could you integrate this addon into MrMC? That would help me tremendously. Thanks in advance.
Author: Jin
Version: 16.5.12
Released: 2017-05-24
Summary: XMLTV EPG Downloader
Host: github.com
Repository: German kodinerds.net Add-ons
Re: EPG Downloader  [SOLVED]
Post by amet » 25 May 2017, 17:10
we cant do python, and getting this into core is just too specific...
Ted377
Re: EPG Downloader
Post by Ted377 » 25 May 2017, 19:24
Really very sad. Is there no other way to integrate EPG?
When I play the m3u with VLC, EPG is displayed to me.
Unfortunately I get TVH not installed on my QNAP NAS. Otherwise it would be no problem.
Re: EPG Downloader
Post by amet » 25 May 2017, 19:52
You can enter URL for epg in simple iptv addon but as far as I know it needs to be in xml format
Ted377
Re: EPG Downloader
Post by Ted377 » 13 Jan 2019, 18:45
25 May 2017, 17:10
Is there now a Chance to do it ?
We got python 😊
SET-TOP-BOX: Apple TV 4
FW: tvOS 12.1.2
Front-End: mrmc 3.8.0
SET-TOP-BOX: Apple TV 4K
FW: tvOS 12.2 (Beta 6)
Front-End: mrmc 3.8.1 (190321.1359)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Ted377
Re: EPG Downloader
Post by Ted377 » 13 Jan 2019, 18:48
It would be a very good buying argument for MrMC 😉
I know many who work with a simple m3u via Simple IPTV Client. Unfortunately, only the EPG is missing for use here. And that is the nice thing about TV 😊
FW: tvOS 12.1.2
NAS: QNAP TS-231P
kamil66
Re: EPG Downloader
Post by kamil66 » 14 Jan 2019, 14:38
Bonjour pas besoin il suffit juste de remplacer get par xmltv sur la ligne m3u : exemple http:// ............com:8000/xmltv.php?...à mettre sur simple client SALUT.
Ted377
Re: EPG Downloader
Post by Ted377 » 16 Jan 2019, 14:31
kamil66 wrote:
14 Jan 2019, 14:38
That's not what I was looking for or asked for. These sources are always very unreliable and short-lived. The Rytec Addon, on the other hand, is constantly being developed and maintained.
FW: tvOS 12.1.2
NAS: QNAP TS-231P
