stutttering since new oled tv
costaud
Re: stutttering since new oled tv
Post by costaud » 29 May 2017, 14:21
Mmm, sorry but I don't have any problem with MrMc until now, I just try to help the guy ;)
Well, I'm sorry, I just noticed that this thread is from April 2016, I think the problen has to be solve now lol
Post by amet » 29 May 2017, 15:40
costaud wrote:
29 May 2017, 13:40
MrMc last version is based on KODI 16 or 17 ?
mrmc was forked when kodi was 15, since then we pulled database changes to keep mysql compatibility... so simple answer, Mysql is kodi 17 compatible.
costaud
Post by costaud » 30 May 2017, 07:25
Well, I made some test yesterday evening.
I tested a serie which has the 3 first episode in 23.976 and all next are 25.
all in 23.976 play well with MrMc, but all next in 25 have smooth issue ( bad 25hz support).
I compared with SPMC 16.2 and KODI 17
No problem with KODI 17, everything is perfect with 25hz files.
With SPMC 16.2, if I remove the advancedsettings.xml file, I have the same issue with 25hz files.
When I put back the advancedsettings file, reboot SPMC, it works well.
So I have to use the same advancedsettings file for MrMc ;)
Does futur MrMc version will include new video engine used in KODI 17 and python ?
Post by amet » 30 May 2017, 07:50
costaud wrote:
30 May 2017, 07:25
only thing we might take from Kodi are some crash fixes , but our video and audio engine is quite a bit different and we will not be using Kodi one.
as for the python, it will NEVER come back.. I'll say it again, NEVER :)
costaud
Post by costaud » 30 May 2017, 09:33
30 May 2017, 07:50
costaud wrote:
30 May 2017, 07:25
Ooopps, I forgot the rules on the top ! :mrgreen:
Sorry ;)
Post by davilla » 30 May 2017, 12:27
MrMC code base is a mix from v16 and v17. DataBase is v17, as well as player and renderer with a few exceptions where we think they are going down the wrong path.
costaud
Post by costaud » 30 May 2017, 13:08
30 May 2017, 12:27
Ok, great ;)
Thanks for the answer.
I'm gonna see with the advancedsettings.xml if 25hz file are better ;)
Post by cosmoxl » 30 May 2017, 16:11
how do we get to the advancedsettings.xml file?
Post by davilla » 30 May 2017, 16:23
cosmoxl wrote:
30 May 2017, 16:11
Which platform ? On tvOS, you can add one (via FileManager) but you cannot edit it or read it but the contents will be shown in mrmc.log during startup.
costaud
Post by costaud » 30 May 2017, 18:46
I tested with a advancedsettings.xml file (the same I created for SPMC 16, copy and paste in the local MrMc install folder, under "userdata"), and now 25hz files play fine ;)
You just have to add lines I posted on one of my last post in a file named "advancedsettings.xml"
