MrMC & Kodi cohabitation
logan_x50
Post by logan_x50 » 10 Jan 2017, 14:01
I have some Video_TS Folders that i can't use MrMC to playback but Kodi will play them.
I have MrMC set for an external database and wondered whether this meant i could have Kodi 17 running with a local database as MrMC v2.8 is running with an external database?
Re: MrMC & Kodi cohabitation
Post by davilla » 10 Jan 2017, 14:30
Video_TS Folders are on the roadmap for being supported.
logan_x50
Post by logan_x50 » 10 Jan 2017, 14:50
thank you Davilla...but in the meantime?
zakaron
Post by zakaron » 26 Jan 2017, 21:34
I currently have Kodi 16.2 on my PC and the latest MrMC on two apple TV devices. They are all on the same MySQL database and share data between all 3 just fine. I normally use my PC to copy new media content to the file server, then run Kodi and update the library - when I go downstairs the new content shows up when I go into that library on MrMC.
The problem is you have v17 - I am very certain they have changed some things in the database, so the current version of MrMC will not likely work with it. That is the biggest reason I have not tried Krypton yet because I'm afraid it will update the database and then MrMC will be left in the cold.
Post by davilla » 27 Jan 2017, 13:19
zakaron wrote:I currently have Kodi 16.2 on my PC and the latest MrMC on two apple TV devices. They are all on the same MySQL database and share data between all 3 just fine. I normally use my PC to copy new media content to the file server, then run Kodi and update the library - when I go downstairs the new content shows up when I go into that library on MrMC.
The pending MrMC v3.0.0 is Kodi 17 compatible. It is in Testflight right now, waiting for Kodi 17 to hit release.
bigbonobo
Post by bigbonobo » 08 Feb 2017, 15:24
Any update on this? Without really thinking about it I updated my raspberry pi (which runs the database) to KODI 17 and now my iPad and Apple TV 4 can't see any of the new files added to the database. My mistake I realise but really looking forward to getting this working again through a MrMC update to the new database.
Any chance you'd like me to try out the TestFlight MrMC v3.0.0?
Post by davilla » 08 Feb 2017, 16:27
few days, finishing up some issues.
