cosmoxl wrote: 07 May 2018, 15:30
There's a new log with Top Gear in it too.
Same. It search shows for "top%20gear%20s24e01"
I see the actual path is "/var/mobile/Containers/Data/Application/E3FD797B-6F2E-4C4F-9991-B091B7EB12CE/Documents/TV/top.gear.s24e01.1080p.hdtv.x264-mtb.mkv", which seems wrong.
There's something wrong. Should't the library be created but have nothing in it if nothing scrapes properly? How would I go about fixing an improperly matched file?
You have to have Settings/Videos/Library "Import all videos" enabled for that
OK, let me try that. but creating a new folder for each show will be a pain. I thought I could have several different shows in the same folder.
Import all videos is enabled.
edit: Thanks. Yep, creating a folder for each individual show did the trick. thanks!
cosmoxl wrote: 07 May 2018, 16:31
It's actually easier that way. Your source is at the "/var/mobile/Containers/Data/Application/E3FD797B-6F2E-4C4F-9991-B091B7EB12CE/Documents/TV" level, which you configure as TV show once and for all.
Thereafter, you add new shows via a new subdirectory and everything happens automagically.
timstephens24 wrote: 07 May 2018, 11:15
I have Apple TV 4's and Apple TV 4K'S for 8 TVs, and the Apple TV 4s can't handle mainly 4K HEVC but also a few VC1. The
When you go into the Movies section, the top left corner says "Services" instead of movies. Same for TV Shows.
Just added "flags". Here it shows services while in intermediate window where all my PMS movie sections are, but shows Movies or TV Shows once I enter any of those sections.
@amet Please, consider renaming that to "Libraries" as intermediate window can have local DB sections as well e.g.:
- MrMC Movies
- Plex Documentaries
- Plex Movies
davilla wrote: 07 May 2018, 20:13
(180507.1807 @20180506-2da108b)
add tvOS DarkMode access
add service.libraryautoupdate
add script.advanced.wol
sync skin.ariana
fixed: don't use HQ when downscaling
A great leap with Ariana!
The Dark Mode doesn’t seem to work, however, do I need to set anything? I didn’t find any Skin setting.
tvOS controls dark mode, we just pass it along.
Doesn’t work; neither when AppleTV Settings/General/Appearance set to Automatic nor manually to Dark.
There is a dark stripe at the top of home screen.
Automatic update seems to work.
EDIT: force quitting MrMC or restarting ATV doesn’t help!
POC might need some more work.
Good luck , it’s 00:25 in centeral Europe, good night and thanks for the excellent work
Last minute EDIT: the black strip at the top vanished; seems to be somehow connected to the library update.
Everbrave wrote: 07 May 2018, 22:21
I don't think Ariana has a dark mode yet, but the new icons make it look a lot better.
