What a tease!davilla wrote: 11 Mar 2018, 20:51 tester of the dayMrMC running Plex for Kodi as a test addon for the return of python.
Testing MrMC 3.5.1
Re: Testing MrMC 3.5.1
SUPERBIF
That looks interesting.davilla wrote: 11 Mar 2018, 20:51 tester of the dayMrMC on AppleTV 4K running Plex for Kodi as a test addon for the return of python.
SUPERBIF
A secondary question. Would it be possible to have the testflight version as a separate version, so you can run both stable MrMC and these "unstable" versions or does that not make sense?
PS: Really looking forward to test that Plex for Kodi addon.
Possible but not likely to happenSUPERBIF wrote: 12 Mar 2018, 11:03 A secondary question. Would it be possible to have the testflight version as a separate version, so you can run both stable MrMC and these "unstable" versions or does that not make sense?
- Montoya
Well, right now I see 4 branches with 28 MrMC versions to choose from, to install from my Testflight app. So from those 4 branches, the latest testflight build of a previous branch can be considered the stable release version I presume, to which you can revert to, if some pre release items in a current Testflight build doesn't work as expected.SUPERBIF wrote: 12 Mar 2018, 11:03 A secondary question. Would it be possible to have the testflight version as a separate version, so you can run both stable MrMC and these "unstable" versions or does that not make sense?
We also do try to make the last TF version of a series, match the release of the same.
RewNex
Will this be in 3.5.1? Hope so keep up the good work.davilla wrote: 11 Mar 2018, 20:51 tester of the dayMrMC on AppleTV 4K running Plex for Kodi as a test addon for the return of python.
SUPERBIF
Okay, thanks for the answer both Montoya and Davilla.Montoya wrote: 12 Mar 2018, 18:11Well, right now I see 4 branches with 28 MrMC versions to choose from, to install from my Testflight app. So from those 4 branches, the latest testflight build of a previous branch can be considered the stable release version I presume, to which you can revert to, if some pre release items in a current Testflight build doesn't work as expected.SUPERBIF wrote: 12 Mar 2018, 11:03 A secondary question. Would it be possible to have the testflight version as a separate version, so you can run both stable MrMC and these "unstable" versions or does that not make sense?
x64Man
Nice, can’t wait.davilla wrote: 11 Mar 2018, 20:51 tester of the dayMrMC on AppleTV 4K running Plex for Kodi as a test addon for the return of python.
- Everbrave
YES! This what I have been waiting fordavilla wrote: 11 Mar 2018, 20:51 tester of the dayMrMC on AppleTV 4K running Plex for Kodi as a test addon for the return of python.
Now, I don't need Kodi to run it
Edit: will the app come with the add-on installed?
Thanks a lot
