Re: Testing MrMC 3.7.0
barong wrote: 05 Jul 2018, 13:38
amet wrote: 05 Jul 2018, 10:42
barong wrote: 04 Jul 2018, 23:00 ...
Couple of oddities:
- When first installing, it asked to try the new skin. Accepting this prompt didn’t activate it.
what skin did you have active before you installed the TestFlight?
Fresh install from the Test Flight app. Wasn’t an upgrade/update.
you didnt have MrMC installed before? it shouldn't have asked you anything if this was a fresh install and you never had MrMC installed
qwijibo wrote: 05 Jul 2018, 12:26 Can't seem to get custom playlists working with Plex libraries. Is this a limitation of the Plex integration or a bug?
did you setup Plex playlists on Plex server?
MrMC custom playlists are limited to MrMC database content
Itzme1234
Post by Itzme1234 »
Interestingly TvOS TestFlight didn’t indicate that the mrmc was ready to update until I clicked into the MrMc icon in TS.
In Plex Ext, I still think users will be confused but what happens when there are checks in both Allow Plex Addon to exit to MrMc and Start Plex on MrMc Startup. The latter only happens one time, and then appears to be broken. You’ve explained why before, but I thought that issue was addressed in the past. Sorry for my confusion.
Post by cosmoxl »
amet wrote: 05 Jul 2018, 13:49
cosmoxl wrote: 05 Jul 2018, 12:51
amet wrote: 05 Jul 2018, 11:41 whats in TF now will most probably be RC for 3.7.0, no more ... it has been a long TF session :)
sure has. is this going to be 4.0 or remain 3.7?
3.7.0 .... 4.0.0 will be a big change :)
:o
jrcorwin wrote: 05 Jul 2018, 10:43 Working perfectly now with my DV layer files!
Excellent, I think I have watched the start of that test content a few hundred times :)
Everbrave
Post by Everbrave »
Yes indeed, 90 pages (on Safari) and still going strong ;)
jpalenz77
Post by jpalenz77 »
I know that right now we are focused on another topics but will you make the hue extension AVF compatible for this 3.7.0 final release?
thanks
_roidy
Post by _roidy »
I've recently tried the Ariana skin which I really like because I'm big fan of the tvOS gui, but I noticed something and I'm not sure weather it's a bug or just a really poor design choice. Pressing the menu button to go up a level in the library opens the top view menu, say for instance I'm in the Episode view and want to return one level to the Season view when I press menu it opens the view menu at the top and I then have to press menu again to return to season view. Is this intentional?
jrcorwin
Post by jrcorwin »
davilla wrote: 05 Jul 2018, 14:50
Same here! Now if Plex would update their add-on, the one being used in MrMc, to include live TV...I could just delete Channels and the Plex app from my various Apple TV’s!
Thanks for all the hard work!
jrcorwin
Post by jrcorwin »
Not sure if this belongs here or not...
So I am experimenting with using the Ariana skin to access my Plex library directly, rather than using the add-on. One thing I am really missing is collection support.
“Group movies in sets” is enabled, but none of my movies tagged as a collection in Plex are being grouped.
