Re: Testing MrMC 3.7.0
Post by cosmoxl »
amet wrote: 03 Jul 2018, 19:07
cosmoxl wrote: 03 Jul 2018, 18:59 ...
Yep, I just tested opacity too.
So, when the screensaver comes on the stream is paused. Pressing play gets it going from where it stopped. There's a log.
https://paste2.org/UXgsp1U1
I wonder if TVOS 12.0 is to blame, I dont have any issues with it on tvOS 11.*.. @davilla ?
I don't think it's a tvos12 problem as then it would effect other apps? I've actually been watching in MrMC for a while now and it's not going to screensaver. So, it's not 100% reproducible.
Montoya
Post by Montoya »
cosmoxl wrote: 03 Jul 2018, 19:32
As reported earlier, I’m on tvOS 11.4 and having cosmoxl on tvOS 12 seems to me that latest Testflight build triggers it.
Post by cosmoxl »
Montoya wrote: 03 Jul 2018, 19:39
Yeah, I can't say for sure but I thought that I probably watched live tv on tvos12 without problem prior to the latest testflight. :D
Montoya wrote: 03 Jul 2018, 18:46
amet wrote: 03 Jul 2018, 18:14
and its all ok using opacity? thats odd .. could you get a debuglog when it happens? I dont see it here
It also happens in Opacity as already reported.
Now, I'm confused. The tvOS screensaver should be enabled to fire when paused. That's as designed. We block (disable) it when playing. When stop/pause, tvOS screensaver is enabled to fire (it's count down starts). When in GUI, each time a users nav's around, the tvOS screensaver timer is reset.
jrcorwin
Post by jrcorwin »
Okay, I just trying playing the same dual layer m2ts file that I have been testing.
  • I did not seeing the macroblocking smear type thing that I mentioned before.
  • What I am getting is serious buffering. It only plays for 2-3 seconds before the circle pops up and spends 10-15 seconds buffering from about 30%-100%.
  • It is NOT triggering HDR of any kind.
Again, none of these issues in Infuse or the native Plex (beta) app. The only downside to the Plex app is that it is transcoding the audio.
Here is a link to my log: https://www.dropbox.com/s/13sxfepus3g4q ... 8.rtf?dl=0
Post by cosmoxl »
davilla wrote: 03 Jul 2018, 20:30
I'm saying that the stream pauses by itself as the screensaver comes on. I'm saying the stream doesn't stop or keep playing in the background. The screensaver coming on and apparent pause happen simultaneously and I'm not doing it. :) I only said that to give you something to look for in the log.
jrcorwin wrote: 03 Jul 2018, 21:54 Okay, I just trying playing the same dual layer m2ts file that I have been testing.
17:44:53.534 T:6172028928 INFO: ffmpeg[16FE1B000]: Metadata:
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: ENCODER : Lavf58.9.100
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: Duration: 02:57:44.60, start: 0.000000, bitrate: N/A
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: Stream #0:0: Video: h264 (Main), yuv420p(progressive), 3840x2160 [SAR 1:1 DAR 16:9], 1k fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: Metadata:
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: ENCODER : Lavc58.12.102 libx264
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp (default)
17:44:53.535 T:6172028928 INFO: ffmpeg[16FE1B000]: ENCODER : Lavc58.12.102 aac_at
Nothing in log is HEVC. They look like the above. H264 with acc audio. Smells like someone is transcoding.
Also;
17:39:56.015 T:6178336768 NOTICE: script.plex: VideoPlayerWindow: Starting session (ID: 10803710408)
17:39:56.015 T:6178336768 NOTICE: script.plex: API: Choice media: 4K, 69.7 Mbps container=mpegts videoCodec=hevc audioCodec=truehd audioChannels=8 id=8791 part:0
17:39:56.015 T:6178336768 NOTICE: script.plex: API: Choice videoStream: <plexnet.plexstream.PlexStream object at 0x280032bd8>
17:39:56.015 T:6178336768 NOTICE: script.plex: API: Choice audioStream: <plexnet.plexstream.PlexStream object at 0x280032c98>
17:39:56.015 T:6178336768 NOTICE: script.plex: API: MDE: Multiple video streams, won't try to direct play
17:39:56.015 T:6178336768 NOTICE: script.plex: API: MDE: MediaChoice: direct playable=False version=4K, 69.7 Mbps container=mpegts videoCodec=hevc audioCodec=truehd audioChannels=8 id=8791
17:39:56.016 T:6178336768 NOTICE: script.plex: API: Forced Transcode; allowDirectStream=False
"Multiple video streams, won't try to direct play"
Waltman
Post by Waltman »
Thanks do adding me to the TestFlight.
some issues
- services: Emby service does not display any media at all
- Home menu: When on on the home menu and movies, tv-shows, music and playlists and media sources are visible in
the left menu, disabling media sources moves down the entire menu list down 1 position from the top.
You now see : Blank - movies - tv-shows - music - playlists
- In Ariana: when choosing icon view, the fanart is not visible in the background.
- In Opacity: Playlist is not selectable in the skin settings
pecinko
Post by pecinko »
Waltman wrote: 04 Jul 2018, 14:24 - In Ariana: when choosing icon view, the fanart is not visible in the background.
I’ve removed fanart as it served no purpose in grid view.
cosmoxl wrote: 03 Jul 2018, 22:10
fixed.
