Testing MrMC 3.8.0 - [Invites Closed]
Everbrave
Re: Testing MrMC 3.8.0 - [Invites Closed]
Post by Everbrave »
tvOS 12.1.2, Ariana
previous version deleted, freshly installed MrMC
General:
- Atmos demo clips do not hang at the end anymore
Emby Client (Server version 4.1.0.6 on Windows; 4.0.0 on Synology DS918+)
- Music Videos do not show-up (no Tile on the Home screen but with Plex they show and play correctly!);
- Music does not play; when trying to play a track, I get a blank screen and can only get-out by force quitting the app
- Selecting TV Shows from the Home screen, shows (place holders for) media shares (two in my case), selecting one share shows the media correctly; but the page title is then "cryptic", e.g. "aHR0cDOVLz ....."
- still, no labels for the shelves on Home screen
Plex Extension (v1.1.6.1; Server v1.14.1.5488)
- still, the upper (top) line does not scroll together with the shelves, i.e. overlaps with the shelve tiles (in Kodi, it does scroll)
cosmoxl wrote: 04 Feb 2019, 03:32 Got the latest.
Nice new entry animation.
The problem of DD+ Atmos files hanging at the end may be fixed. Will continue to test.
The problem of the previously mentioned HDR file not triggering HDR is still there.
https://paste2.org/sd0WyNYY
21:27:16.113 T:6140981248   DEBUG: FactoryCodec - Video: avf- - Opening
21:27:16.113 T:6140981248   DEBUG: FactoryCodec - Video: avf- - Failed
21:27:16.113 T:6140981248   DEBUG: FactoryCodec - Video:  - Opening
21:27:16.113 T:6140981248  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
21:27:16.113 T:6140981248   DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 4 threads
21:27:16.113 T:6140981248 DEBUG: FactoryCodec - Video: ff-hevc - Opened
AVF is failing forcing it to fallback to ff-hevc
email media name so I can go and find it for testing.
Post by cosmoxl »
davilla wrote: 04 Feb 2019, 15:03
Done. Sent to you at mrmc dot tv.
Everbrave
Post by Everbrave »
My audio configuration is 4 for Dolby surround and 2 for Atmos (no centre and no subwoofer).
What is the proper channel setting (Settings/System/Audio) while testing Atmos content?
Post by timstephens24 »
Everbrave wrote: 04 Feb 2019, 18:08 My audio configuration is 4 for Dolby surround and 2 for Atmos (no centre and no subwoofer).
So you have a 7.1.2 setup? The correct settings should be setting it to 7.1.
MrMC's audio channel does not matter for Atmos decoder. It's native and passed through to the a/v receiver for actual decoding. That is for AppleTV4K.
cosmoxl wrote: 04 Feb 2019, 15:58
I can always depend on cosmoxl tossing me a curveball :)
For this one, it's hev1 which means sps/pps/vps are in actual stream, not in extradata. VideoToolBox decoder knows how to defer the "open" until it can pull them out of the stream but CDVDVideoCodecAVFoundation does not have that handling yet. On the list now.
It does show the power of the AppleTV4K cpu :) Does 1080p HDR HEVC sw decode just fine.
Post by cosmoxl »
davilla wrote: 05 Feb 2019, 03:56
:D
Everbrave
Post by Everbrave »
timstephens24 wrote: 05 Feb 2019, 00:12
5.1.2 (FR, FL, SR, SL, AtmosR, AtmosL, no Centre, no Sub), so only 6 channels are powered.
If I understood @davilla correctly, ATV will recognize the channel configuration and adapt accordingly.
The channel setting stops at 7 (no 7.1)
EDIT: There is, in fact, 7.1 setting; seems I couldn't/didn't scroll far enough; sorry!
Everbrave
Post by Everbrave »
davilla wrote: 05 Feb 2019, 03:41
So, if I understood you correctly, the ATV4K will detect the driven channels? If so, could I then the channel setting at 2 or set it to 4, 5.1 or 7?
EDIT: my current setting is 5.1; works fine but just wanted to make sure. Thanks
