koying wrote: 08 Feb 2019, 15:13What do you precisely mean by "lost the options"?maglione66 wrote: 08 Feb 2019, 15:03 Hi, the last version 3.8-0 Feb 8 1019, lost the options for passthrough DTS HD, Dolby TrueHD, the previous version 3.7 work Ok, this don't work HD audio. Nvidia Shield TV. Thanks!
maglione66
I'm also seeing a problem where MrMC hangs when trying to play the new startup splash screen. Force closing and clearing cache seems to have fixed this for me.
I can also confirm audio is only PCM out now. I see stereo when trying to play a TrueHD Atmos track and 5.1 PCM when trying to play a regular DD track.
Where should I send a sample of 1080i DVR that doesn't play right with AMC surface?
The DVD rips that don't play with AMC were done from my DVDs with makemkv straight to mkv.
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 1 h 31 min
Bit rate mode : Variable
Bit rate : 5 181 kb/s
Maximum bit rate : 9 800 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 24.565 FPS
Original frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.610
Time code of first frame : 00:59:59;00
Time code source : Group of pictures header
Stream size : 3.33 GiB (92%)
Language : English
Default : No
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Original source medium : DVD-Video
- koying
Mmm... That log seems fine.
What I need is:
- MrMC doesn't start
- You kill it via the Shield app menu (I assume that's what you do)
- Restart MrMc (I assume it starts at that point)
- Get mrmc.old.log
- koying
You can push it to https://nextcloud.semperpax.be/s/DeeCbJz3AMDFRD9cosmoxl wrote: 08 Feb 2019, 15:55 Where should I send a sample of 1080i DVR that doesn't play right with AMC surface?
semperfixd
Log old after what I did as you saidkoying wrote: 08 Feb 2019, 15:55Mmm... That log seems fine.
What I need is:
- Get mrmc.old.log
https://pastebin.com/P23wH8AL
log new: https://pastebin.com/DrxVZCXh
Thanks, uploaded.koying wrote: 08 Feb 2019, 16:01You can push it to https://nextcloud.semperpax.be/s/DeeCbJz3AMDFRD9cosmoxl wrote: 08 Feb 2019, 15:55 Where should I send a sample of 1080i DVR that doesn't play right with AMC surface?
- koying
I might have an idea for both startup and passthrough issue.
Will update the beta in 1 hour or so...
EDIT: Uploaded...
EDIT: Uploaded...
maglione66
The new update no fix yet the passthrough audio HD.
confirmed. and just to be clear, I get no passthrough at all.
