That Skyscraper info looks just like my Atomic Blonde does (dvhe EL), which plays flawlessly on both LG and Vizio TV's, sorry for assuming Sony should be the same. As for your bad mi:fallout, running it through mkvmerge multiplexing should find/fix the errors on the fly and give you a TSMuxeR demuxable file.sorenat wrote: 16 Dec 2018, 10:33
While I'm waiting for the Atomic Blonde I did run few experiments with the Skyscraper. First of all TSMuxer extracted all tracks without any issues, which means that my MI:Fallout rip is definitely off. I managed to combine BL and EL+RPU into a single mp4 file, but unfortunately, not into a single video layer:
Video #1
Format : HEVC
Commercial name : HDR10
Format profile : Main [email protected]@High
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 1 h 42 min
Bit rate : 69.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.348
Stream size : 49.5 GiB (85%)
Default : No
Encoded date : UTC 2018-12-15 19:22:12
Tagged date : UTC 2018-12-15 19:22:12
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 986 cd/m2
Codec configuration box : hvcC
Video #2
Format : HEVC
Dolby Vision : 1.0, dvhe.07.06, EL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 11.2 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.226
Stream size : 8.03 GiB (14%)
Default : No
Codec configuration box : hvcC+dvcC
I can play the file with a Sony built-in video app, but it's recognized as HDR10.
I think mp4muxer has preset profiles to choose from as creating your own might require an official Dolby CMU? definitely try every little string you think could work though cuz if you get a single layer file running properly that opens up a plethora of device compatibility, MrMC included. although I still think if you crop a sample of your dual layer mp4 for them to test it might just play. I tried with TSMuxer but when I cropped the movie to 2mins long the output file had no 2nd video track anymore, so not sure what what program is required? you might have better lucksorenat wrote: 16 Dec 2018, 10:33
I also ran single DV layer LG demos through a media info app and found the following:
Format : HEVC
Format profile : Main [email protected]@Main
Dolby Vision : 1.0, dvhe.05.09, BL+RPU
Codec ID : dvhe
Duration : 1 min 16 s
Bit rate : 28.6 Mb/s
Frame rate : 60.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.057
Stream size : 261 MiB (98%)
Encoded date : UTC 2017-09-19 18:54:04
Tagged date : UTC 2017-09-19 18:54:04
Where the most interesting part is: Dolby Vision: 1.0, dvhe.05.09, BL+RPU
So I tried to repeat the conversion with a different profile (--dv-profile 5) and while I still got 2 video layers, the Dolby vision string looked very similar to that from LG demos (Dolby Vision: 1.0, dvhe.05.03, BL+RPU) and what is even more exciting a Sony built-in video app recognized it as DV! The bad thing is that video was so dim to the point of being unwatchable.
I'm wondering if it's possible to force mp4muxer to produce dvhe.05.09, BL+RPU.
exciting times!
